Purchase: $20k Budget
Discussion in 'General Tundra Discussion' started by vmass, Feb 20, 2023.
  1. Feb 20, 2023 at 6:37 AM
    vmass
    vmass [OP] New Member
    Morning! After owning Rams and Fords, I would like to give a Tundra a try.
    I understand that 20k is on the low side of these trucks, but they seem to be out there. Looking for any advice or recommendations of what to look for or more importantly, what to stay away from.
    I may consider putting a plow on for personal use only.
    In the 20k range, what mileage is too much and what year is best?
    Thanks for any help you care to offer and enjoy your day!
  2. Feb 20, 2023 at 6:49 AM
    2mchfun
    Don't worry about mileage too much, look for excessive wear around trailer safety chain loops, wear on the brake pedal, seat side bolster wear, seat belt wear, all of these things will help you determine if it was mostly highway driven, excessive towing, or a bunch of stop and go. Secondly, rust! Look for frame rust! Lastly, engine mounts, steering rack mounts, shock mounts, excessive wear on these also speaks volumes. I'd say get the word out and be patient while trying to find a well kept truck that was left behind by an older gentleman who has checked out recently.
  3. Feb 20, 2023 at 6:51 AM
    Think you’ll be harder pressed to get a 2014+ (the facelift year) for $20k without a bunch of miles. Only 3 available over 2014 under $20k within 100 miles of me and they all have 200k plus miles. 200k isn’t the end of these trucks, with good maintenance they should go at least twice that and beyond, but all the consumables on the truck will need attention. Suspension, breaks, bushings, hoses etc.
    vmass[QUOTED][OP] likes this.
  4. Feb 20, 2023 at 7:12 AM
    vmass
    Great advice, thank you. I have read a bit about rust issues, specifically the frame. I assume this will be visible or are there some situations with these trucks to look rust free with issues being somewhat hidden............
  5. Feb 20, 2023 at 7:14 AM
    vmass
    Agreed, I am not apposed to pre '14, they seem to be well loved. I would be more comfortable with 130k miles or less and settle for an older, well cared for truck.....easier said than done.
  6. Feb 20, 2023 at 7:21 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    A well-maintained 2010-2013 seems to be your best bet. For these trucks, meticulous maintenance records are a bigger selling point than low miles.
    I’ve played around with the idea of getting a pre-2014 Tundra just so I could swap the Sequoia transfer case into it and have an unlocked center diff. My 200 series is spoiling me in that regard.
    JLS in WA, JRS and texasrho83 like this.
  7. Feb 20, 2023 at 8:11 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This.
    I'd personally go for a nice 2012 if tomorrow my 2016 went belly up. Preferably one with the SAIS delete.
    Terndrerrr[QUOTED] and JRS like this.
  8. Feb 20, 2023 at 8:17 AM
    vmass
  9. Feb 20, 2023 at 8:23 AM
    vmass
  10. Feb 20, 2023 at 8:27 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  11. Feb 20, 2023 at 8:31 AM
    vmass
    This would have the SAIS, is this a big concern?
    HewittTech01 likes this.
  12. Feb 20, 2023 at 8:57 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It will eventually be a concern.
    Read:
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
  13. Feb 20, 2023 at 9:26 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
  14. Feb 20, 2023 at 9:44 AM
    vmass
    I am not familiar with the different trim levels, Platinum above or below or just different than the Limited?
  15. Feb 20, 2023 at 9:58 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It's one trim level above.
  16. Feb 20, 2023 at 10:13 AM
    vmass
    FlyingWolfe likes this.
  17. Feb 20, 2023 at 10:14 AM
    vmass
  18. Feb 20, 2023 at 10:15 AM
    vmass
  19. Feb 20, 2023 at 10:16 AM
    vmass
  20. Feb 20, 2023 at 10:17 AM
    vmass
  21. Feb 20, 2023 at 10:19 AM
    vmass
  22. Feb 20, 2023 at 10:19 AM
    vmass
  23. Feb 20, 2023 at 10:21 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Damn that rust is not good. Also looks like they either replaced that CV boot after a leak or it's still leaking. You could easily talk them down a couple grand then scrub all that rust off and seal it, or pass on the deal. If they aren't willing to budge on price, I'd walk.
    Shocks also look OEM but that's just a guess on the one pic you posted. What's the front end look like?
  24. Feb 20, 2023 at 10:29 AM
    vmass
    Understood, that rust is pretty common here n New England. Rockers look
    Really. Haven’t had it off the lift yet, they are doing maintenance.
  25. Feb 20, 2023 at 10:35 AM
    vmass
  26. Feb 20, 2023 at 11:00 AM
    blenton
    blenton New Member
    I'm not from that area, but from what others have posted before, that looks pretty decent for New England. The hitch looks pretty unhappy, as does the lower control arm. Looks like they've replaced a wheel caliper, which isn't necessarily a bad thing. Those shocks, though, out to be replaced, IMO. It has the TRD exhaust, as well, so it should sound purrrrdy...
  27. Feb 20, 2023 at 11:17 AM
    AZBoatHauler
    So.Arizona
    OMFG I'm glad to live in the desert.
    :tumbleweed:
  28. Feb 20, 2023 at 11:21 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    I searched for months throughout New England. Literally did not find a truck for 20k or below that wasn’t too rusted to consider buying, or had more than 2 recorded service records on my Toyota. Good luck.
    I flew out to missouri and drove home
    texasrho83 likes this.
  29. Feb 20, 2023 at 11:25 AM
    AZBoatHauler
    So.Arizona
  30. Feb 20, 2023 at 11:43 AM
    vmass
    Not a bad idea!
