Putting in leveling kit using spring compressor, the easy way?
Discussion in 'General Tundra Discussion' started by coltthecoonhound, Jan 7, 2021.
  1. Jan 7, 2021 at 7:50 AM
    coltthecoonhound
    coltthecoonhound [OP] New Member
    Bill
    2021 Toyota Tundra
    2021 TRD
    Hello,
    I have a 2021 Tundra and want to add a 2.5" leveling kit, puck, on top of strut. Rather than go to all the rigmarole of suspension removals, I bought a higher end spring compressor (the one that comes in the red box, HD with keeper). My thought is to remove the wheel, suspend truck and recompress with floor jack to compress strut, attach spring compressor, un-attach strut from top housing, suspend truck then proceed to lowering jack under suspension and drop top of strut out of housing and sneak/bolt in puck, push back into place re-asserting strut into housing, reattach and done???? Remove spring compressor then get re-alignment of course.
    ***Has anyone actually done this, please?
  2. Jan 7, 2021 at 7:55 AM
    SouthWestGA
    SouthWestGA New Member
    Please don’t do it. Don’t be that guy who buys a brand new truck and a cheap $50 lift kit.
    Are you aware of the alignment issues by having a lift with the factory upper control arms?
    They are limited in range of motion. Anything over 2 inches and you take a risk that your alignment may not be able to get “in spec” and result in alignment/tire wear or handling issues. I would not want a new truck done cheap,or messed up from the beginning
    Also,it is widely known that puck lift spacers cause a crappy ride,versus a proper lift. The pucks are popular since they’re cheap.
    I’m sure experts will be along shortly
    des2mtn and Sunnier like this.
  3. Jan 8, 2021 at 10:40 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Compressing the spring won’t compress the shock so unless you have someway of keeping the shock compressed after lowering jack this method won’t work.
  4. Jan 8, 2021 at 10:44 PM
    Tundyfundy
    Bay Area, CA
    All this just so you don’t have to undo 1 extra bolt at the bottom of the shock? Seems like a bad idea. If you do it the right way you won’t even need the spring compressor. Just undo the shock and take it out Whole then reinstall with puck. I think your thinking too hard about this one. Also you won’t find too many fans of spacer lifts here but to each their own. Welcome to the forum!
    saybng likes this.
  5. Jan 8, 2021 at 11:31 PM
    TXTundra2722
    2015 Black Tundra
    Dang, another brand new one and just going straight to the questions without any introductions! :)
    Guess we'll take you anyways.....Welcome from TX! I also agree that your WAY over thinking this one and if your heart is really set on a puck or spacer lift then go for it..... but your down grading from factory with this.... the ONLY thing this will accomplish is raising the front. If you save a few more dollars then you can actually get some decent leveling kits and also improve the ride.
    :spending:
    Tundyfundy and saybng like this.
  6. Jan 8, 2021 at 11:46 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    :crazy::facepalm:
    Tundyfundy likes this.
