Question about wiring dual pods to fog light switch...
Discussion in 'Lighting' started by obz, Mar 18, 2018.
  1. Mar 18, 2018 at 7:01 PM
    obz
    obz [OP] Not a New Member
    Utah
    So I'm picking up a new bumper and will be running 4 total rigid pods and 1 rigid 20" LED light bar. I wanted to hook the 4 pods to the fog light switch that's on there factory. I know I can just connect 2 of the pods directly to the fog wiring with no issue, but 4 would be too much draw to do this (30W per pod is what they're listed on Rigid's site). So the question, how do I pull it off? I think the pods each come with a switch and relay so I'm sure I could leverage those. Thanks lighting gurus!
    831Tun likes this.
  2. Mar 18, 2018 at 7:19 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You can use a relay. The + from the stalk goes to the relay as a "trigger" larger power from relay to the + of fog. You'll need another fused power from the battery to the relay and a ground out of the relay.
  3. Mar 18, 2018 at 7:30 PM
    obz
    Utah
    You think a single relay could support 4 pods? Also, any idea where is the easiest way to tap into the fog switch without tearing the whole column apart?
    831Tun[QUOTED] likes this.
  4. Mar 18, 2018 at 7:39 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well, for reference, I've got a 240w light bar on a single relay. You might check the fuse box under the dash? I'm no electrical guru and it'd take me a bit of fussing to make work. Maybe @RowdyRon has an idea, he's much better at this than I.
    NewImprovedRon likes this.
  5. Mar 19, 2018 at 9:01 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, Looks like there's no problem for you using a single relay.
  6. Mar 19, 2018 at 9:24 AM
    TOTU17
    TOTU17 New Member
    If you wanted to be extra cautious you could use each side as a trigger. But you won' need to, 4 lights @30w ea is no problem for a light bar harness that us provided. I have ran more than that amount of watts with the fog connection
  7. Mar 19, 2018 at 9:57 AM
    TOTU17
    TOTU17 New Member
    You can order some h11 connectors and solder them to the wire harness for plug n play.
  8. Mar 19, 2018 at 10:02 AM
    obz
    Utah
    Do you mean and bypass the relay all together and plug directly into the fog harness from the pods?
    831Tun likes this.
  9. Mar 19, 2018 at 10:07 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think he's talking about creating your own PnP harness.
  10. Mar 19, 2018 at 10:10 AM
    TOTU17
    TOTU17 New Member
    I was saying plug the harness into the stock harness. But I have used just a splitter and bypassed the relay harness. But I feel you may be a little more thorough than me, lol
  11. Mar 19, 2018 at 6:00 PM
    obz
    Utah
    Thank you guys for your help! I'm going to give it a go and see what happens. I should be good on the amperage to a single relay (2.14 amps per pod and 15.29 amps from the 20" bar). I'll be sub 30 amps and getting a 40 amp relay should work great!
    NewImprovedRon and 831Tun like this.
  12. Feb 4, 2019 at 10:03 AM
    vancew01
    vancew01 New Member
    Wes
    2011 Blue TRD CM
    7in BDS 37 Toyo trail grappler MTs
    Holy thread revival...
    I am looking to do the same but for 4 halogen fog lights. Is the relay still necessary? I would assume yes. I am not highly knowledgeable in the "flow of electricity" but I'm hella good at following instructions and cutting/splitting/rigging things to work properly. I want to err on the side of caution and do the relay, just wandering if it's not absolutely needed and I can just make some pigtails off the factory fog light wires. If I do need relay, should I do two? Using your math, 14amps draw. Will follow all other directions (ground, fuse, etc)
    42W per light. Dorman 923-850 halogen fogs
    TIA
