Question on putting weight in rear for winter driving
Discussion in '2nd Gen Tundras (2007-2013)' started by Jon1979, Oct 29, 2019.
  1. Oct 29, 2019 at 7:17 AM
    Jon1979
    Jon1979 [OP] New Member
    Jon
    Upstate NY
    2011 Gray Tundra SR5 4.6L V8
    Hello everyone.
    It has been almost 15 years since I had a truck. My last one was an old 86 Chevy and I use to put cinder blocks across the rear axle in the winter. Do any of you that live in the snow belt region add weight to the bed of your Tundra's?
    If so I would like to know how much and what kind. I used bags of tube sand in the back of my old rear wheel driver car before. I am running 4 studded snow tires and my rig is 4 wheel drive.
    Thanks.
  2. Oct 29, 2019 at 7:33 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I don't put any extra weights in the back. When it begins to slide, I just flip the 4 wheel drive switch and it drives like a different truck. Your snow tires should do even better than my mud tires.
    shellshock and Kerch71 like this.
  3. Oct 29, 2019 at 7:35 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I don't think it necessarily needed, especially with 4wd and 4 studded snow tires. You could fill a bucket or tub with sand and secure it in the bed if you really want. I like having a bucket of sand, a shovel, and gloves just in case I get stuck, but the sand is for the sand, not for added weight.
    GODZILLA and graysquirrel like this.
  4. Oct 29, 2019 at 7:46 AM
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    I live in northern WI and have not found it necessary to add weight to the back of my CrewMax.
    With the weight of the bigger cab being more distributed over the rear axle than a regular cab truck it's balanced more like an SUV and less like a pickup on snowy roads.
    shellshock, vhstejskal and 7.62Tundra like this.
  5. Oct 29, 2019 at 7:49 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    If you are looking for weight, those bags of concrete mix weigh 60lbs. and they’re like $4/piece at the depot. Throw em in some trash bags to avoid dust and you’re good.
    BigSkyTaco, tbutler and MJoeP like this.
  6. Oct 29, 2019 at 8:48 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Never had to in CO
  7. Oct 29, 2019 at 8:50 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I personally use 300 pounds of sandbags, mainly just Incase my 4wd decides to act up at the wrong time. Happened to me once in my 08 Ram, made my snowy drive no fun. Once bitten twice shy lol
  8. Oct 29, 2019 at 11:47 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    My spare is in the bed, and my Nittos handle snow very well, especially in 4wd. Not sure how much difference the spare makes. I'm sure it helps, given it's a 37 and weighs a freakin ton. My bed is also 6.5' on a CM so the extra weight towards the cab helps with distributing the center of gravity.
    JH5370, Pinay and Pudge like this.
  9. Oct 29, 2019 at 3:08 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    You have a 6.5' bed and a Crew Max?
    gdisarray likes this.
  10. Oct 29, 2019 at 3:15 PM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Damn thing is heavy enough as it is. Especially with my cap.
  11. Oct 29, 2019 at 3:21 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Excellent point. Throw a couple of fat chiXX in the back seat to help keep you warm if you get stranded. That's called insurance.:D
  12. Oct 29, 2019 at 3:21 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    I ran mine last year with nothing in the bed. Pulled fine, and never missed a beat. North East Pennsylvania
    Pinay likes this.
  13. Oct 29, 2019 at 3:39 PM
    Kerch71
    Mechanicsville VA
    Well spotted sir. Yes I do. Custom extension of frame by Precision Bodylines.
  14. Oct 29, 2019 at 3:52 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I always looked at it as added weight when that ass swings around.
    Owned trucks most of my life and never added weight to the back.
    I live in the lake effect area where we get feet at a time.
    Pudge likes this.
  15. Oct 29, 2019 at 4:04 PM
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
    I commute ~50 miles in Montana winters. I put 300# in the bed. I like to keep the weight on top of or just in front of the axle. Improves traction and I think it rides better. Also drop the tire pressure slightly in winter.
  16. Oct 29, 2019 at 4:31 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    i've been driving my double cab in 2wd all over cheyenne in this for two days...no issues. when you start slipping the traction control takes over and does it's job. haven't used the 4x4 dial yet. four trips between the shop and home, three trips to tire store to get tires on the parts truck, took a floor buffer back to the rental place.
  17. Oct 29, 2019 at 4:41 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Normally I dont add weight. But if I do its snow. Got to clear it off the driveway, just throw it in the bed for added weight. Otherwise 4x4 will do the trick. Just remember 4x4 is for traction, and to get going. It doesnt help you stop.
  18. Oct 29, 2019 at 4:43 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Knowing how to drive in snow is better that adding weight.
  19. Oct 29, 2019 at 4:48 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
  20. Oct 29, 2019 at 4:48 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Perfect setup for some GREAT traction !!
    @Jon1979
    I have used sand bags in other trucks but this will be my first winter in the new Tundra !
    I think at least a 100lbs will be a good idea in the tundra-
    JM2C
    WILLINH and Kerch71[QUOTED] like this.
  21. Oct 29, 2019 at 5:23 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    I live in Erie County in PA and find that 70lbs of tube sand Over each wheel makes a world of difference.
  22. Oct 29, 2019 at 5:41 PM
    bkri
    bkri New Member
    2002 Tundra SR5
    Just wondering how much wt everyone here would recommend adding in the bed of the truck for winter. I have 5 5 gallon buckets that I'll have a mix of sand and salt in. My Tundra is a 2002 access cab with stock rear suspension. Any thoughts?? Thanks.
  23. Oct 29, 2019 at 5:45 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    We get 2-5' of snow each winter..I'll probably just let the bed fill up and use some free weight from mother nature
    ColoradoTJ and jewsNbrews like this.
  24. Oct 29, 2019 at 5:50 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Threads were merged for continuity.
    Wynnded and jewsNbrews like this.
  25. Oct 29, 2019 at 6:04 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    I usually throw 3-400 pounds in the bed. Yesterday I was in town with my Tundra and decided to get some sand bags for my kid (2WD Tacoma), it was snowing and icy, the truck handled way better with the weight in the rear, the back end just stays planted that much better. After I threw them into the kids truck I was kicking myself for not getting enough for me as well......WTF was I thinking.....
    jewsNbrews likes this.
  26. Oct 29, 2019 at 6:12 PM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    I’ve got 120 lbs of sand back there. I think it absolutely helps. I wonder if a bit more would be better.
  27. Oct 29, 2019 at 6:58 PM
    I’ve seen people use sand bags (tube) from Home Depot and strap them down.
    I usually have stuff in the bed anyway. So no extra weight is needed for my situation.
    Tires really make all the difference. Growing up in Montana, my parents never had a 4x4 vehicle and got around just fine.
    Jengel451 and jewsNbrews like this.
  28. Oct 29, 2019 at 6:59 PM
    Aerindel
    Aerindel New Member
    Montana
    Montana.Steep hills that I have to get up and down everyday. I don't do any weight as I think it does more harm than good when its steep.
    I do put tire chains on my front tires pretty often though.
  29. Oct 29, 2019 at 7:13 PM
    On the front? Interesting.
    I always put them on the rear axle on a IFS vehicle.
  30. Oct 29, 2019 at 7:50 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    I add 3 sand tubes (240lbs) and makes a world of difference when leaving the truck in 2wd. Of course I put it 4wd when it's bad.
