Question/problem about REDARC Tow-Pro Liberty
Discussion in 'Towing & Hauling' started by apwisher, Jul 12, 2022.
  1. Jul 12, 2022 at 8:41 PM
    apwisher
    apwisher [OP] New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I installed a REDARC Tow-Pro Liberty a couple weeks ago and finally got around to hooking up my trailer last week. Unfortunately I had no trailer brakes. I'm trying to track down whether the problem is with the trailer or the controller. I'm using the Brake Controller Harness (TPH-021) from REDARC. here are my observations:
    1. With the trailer not hooked up, I get a BLUE Breathing (pulse) when the Override button is pushed, nothing else.
    2. With the trailer hooked up, I get the same BLUE Breathing (pulse) when the Override button is pushed, which according to the REDARC manual means the trailer brakes have not been detected OR the trailer is not plugged in.
    3. The manual states that "Active Calibration constantly monitors the vehicle’s direction of travel and allows the Tow-Pro® Liberty to ‘learn’ and continuously confirm its mounting orientation. This process occurs whilst the vehicle is
    moving and the brake is applied and will occur with or without a trailer connected, for most vehicles." This did not occur that I ever saw.
    My question is this: when you are not connected to a trailer, is the pulse normal? Is there no indication that the brakes are being pressed etc? If that is the case, then I suppose I can eliminate a bad controller. Does the controller button do its various color LEDs only when a trailer with electric brakes is detected?
    I do have one of those 7 blade connector testers in there and there is no response on the electric brake LED other than a very faint flickering. but maybe that is normal if the controller doesn't detect the brakes. I picked up the trailer from my parents and they said the brakes worked, but that is no guarantee that is true.
    Ideas welcome.
  2. Aug 15, 2022 at 1:54 PM
    bill-55
    bill-55 New Member
    Bill
    Hi there I just purchased a redarc Toe Pro Liberty as well Have not tried it out yet either the problem I have right now is the Distance to empty is way out of wack I have 3/4 of a tank and it say's have 800 plus Km to go which is usually about 500 plus .But back to the set upp all Im getting is the blue when pushing the controller button and then it fades away , . I need to check into more about setting it up as well
  3. Aug 15, 2022 at 2:00 PM
    apwisher
    Everett, WA
    thanks for the info. I did find my camper brake had a severed wire and when I fixed that it seems to clear everything up for me. The fading blue light is normal with nothing connected,
    Cheers!
  4. Aug 15, 2022 at 3:03 PM
    bill-55
    bill-55 New Member
    Bill
    thanks I just disconnect my Battery for 20 minutes and hooked it back up now it reads 700 plus instead of 800 plus anyway I will drive around some and see if it self sets on its own at a lower #
