Quick Release Steering Wheel?
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Mar 6, 2022.
  1. Mar 6, 2022 at 12:56 PM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    I'm thinking about how to make my truck as theft-proof as possible. The number of car thefts across America are going through the roof. Landed on the quick-detach steering wheel option, easy pop-off and pop-back-on. Short of towing the whole truck, I think having no steering wheel makes it pretty damn theft-proof. It doesn't stop any smash-and-grabs but at least my truck will still be in the parking lot after work.
    Has anyone done this on a 1st gen Tundra? Anyone used NRG brand?
    Doing a quick Google search doesn't yield me very many results. Apologies if this has already been addressed in another thread.
  2. Mar 6, 2022 at 1:04 PM
    I'd need a way to trick the computer in my state, pretty sure any light, including an airbag malfunction light, would have me unable to pass inspection. I'm sure there's probably a way to bypass the airbag sensor though, using a resistor or some similar method, but maybe your state's not like mine.
    What I would say before you spend the money is this, thinking about history: If thieves want it, they'll grab it as we've seen with wheel thefts. People started adding wheel locks, so thieves started carrying assortments of common ones out there. If they don't have one on-hand that works, they'll use clay or silly putty to make a cast, then come back to you later. Likewise, you'll be doing all this work to swap to a pop-off wheel, I have no doubt any self-respecting car thief has a rig for just that situation...
    Kinda like that "The Club" steering wheel product. Worked great for a couple of years. Then thieves realized you just need a pair of bolt cutters to cut thru the thin steel ring inside the steering wheel to split the wheel and remove it.
    Anyway - genuinely curious, how do you plan to deal with relocating the cruise lever, wiper stalk, light stalk, etc?
  3. Mar 6, 2022 at 7:25 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I feel like at the very least getting rid of the airbag to prevent the very slight risk of theft doesn't seem like a great tradeoff. To each their own.
    Darkness and EvilMilkshake like this.
  4. Mar 6, 2022 at 9:32 PM
    DarkMint
    Ben
  5. Mar 6, 2022 at 9:35 PM
    DarkMint
    Ben
    Fair point, nothing is theft-proof. But I see it as more of a deterrent than a "club" steering wheel lock that can be defeated with a simple set of bolt cutters or something to saw through the wheel itself.
    I saw some people say thieves can drive without a steering wheel using vice grips. I'll need a wheel hub lock for that problem.
    shifty`[QUOTED] likes this.
  6. Mar 6, 2022 at 9:38 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Hidden kill switch to the fuel pump. And dont ‘hide’ it under the dash. Get creative and hide the switch somewhere new. The kill switch to my jeep is under the drivers seat.
    bmf4069, Jack McCarthy and Tundra2 like this.
  7. Mar 6, 2022 at 9:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    In one of the cubbies under the rear seat.
  8. Mar 6, 2022 at 9:42 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    you wanna be able to flick it without anyone noticing. In the ashtray?
  9. Mar 6, 2022 at 9:44 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Too obvious. Put a PLC in it so the floor switch won't work unless you press it a certain pattern? I don't know.
    bmf4069 and Sirfive[QUOTED] like this.
  10. Mar 6, 2022 at 9:50 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  11. Mar 7, 2022 at 3:17 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
  12. Mar 7, 2022 at 5:18 AM
    Hide it in plain sight: In a bank of switches. :D
    Darkness and Jack McCarthy like this.
  13. Mar 7, 2022 at 6:45 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Console dash light. Whoever changes it from the max setting? Repurpose it for the kill switch.
    Darkness likes this.
  14. Mar 7, 2022 at 6:50 AM
    Actually this comment gave me an idea. In the audio/musical world, some amps, guitars, and other things come with push-pull potentiometer style knobs. If knob is in standard pushed position, it adjusts the level of one thing up and down. When in pulled position, it adjusts another thing up and down. I wonder if you could find something like that for the dash light, where, when pulled out, it adjust the dash light, and if you push it in and crank it all the way down, it kills ignition. Or maybe a knob that's push-pull where, when pushed in, one circuit is "OFF" and when pulled out, it adjusts the other.
  15. Mar 7, 2022 at 6:51 AM
    DarkMint
    Ben
    My top 2 concerns with the kill switch option:
    1) I don't know how to wire things. Electrical stuff is scary to me beyond light bulb swaps and plug-and-play headlight harnesses. How difficult is setting up a kill switch?
    2) My experience with killswitches on 2-stroke motorbikes has made me perceive them as unreliable, aka cause lots of little electrical problems here and there, or sometimes even kicking in at the worst times. How safe would a killswitch be on a Tundra provided I don't hit it by accident?
  16. Mar 7, 2022 at 6:55 AM
    Jack McCarthy
    Bill
    North of Boston
    Yeah, they make them. I don’t see anything unusual about that knob size to implement it.
  17. Mar 7, 2022 at 6:56 AM
    Jack McCarthy
    Bill
    North of Boston
    My old car had a toggle switch in the glove box under all my crap.
  18. Mar 7, 2022 at 6:58 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Every vehicle ive ever owned has had a fuel pump relay kill switch. The only trouble is ever given me is when i park in a bad area, the next morning or whatever the first time i try to start it and had forgot i flipped it, its kinda embarrassing, and i look at myself in the mirror and call myself a dumbass.
    havent done the tundra yet. Would be a decent little project.
  19. Mar 7, 2022 at 7:12 AM
    Definitely would. But my bigger concern, frankly, is someone sawing off my cats. Bastard move that puts me out $3k. I'd almost rather they stole the truck, stripped and scrapped it. There's still enough good options on the market, I could probably get my money's worth out of it and have enough to upgrade handsomely.
    Jack McCarthy likes this.
  20. Mar 7, 2022 at 8:13 AM
    Jack McCarthy
    Bill
    North of Boston
    A simple mechanical toggle switch (you can buy locking ones) would be pretty reliable as long as it's kept out of the environment unlike a motorbike I would assume.
  21. Mar 7, 2022 at 8:18 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's pretty brilliant really. Disguise it as a fog light switch or seat warmer or something.
  22. Mar 8, 2022 at 4:02 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You've got enough people on here that know electrical that we could walk you through it. Some could even draw you pics. We like pics. Like, a lot.
  23. Mar 8, 2022 at 7:47 AM
    DarkMint
    Ben
    OK I just realized switching the steering wheel would make me lose cruise control. That + losing the airbag makes it no longer an option for me at this time. Looks like I'm going the killswitch route for sure.
    bmf4069[QUOTED] and shifty` like this.
