R1 concepts brakes
Discussion in 'General Tundra Discussion' started by TheBeast, Aug 21, 2017.
  1. Aug 21, 2017 at 3:07 PM
    TheBeast [OP] The Beach
  2. Aug 21, 2017 at 5:38 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    From what I've heard, good things.
  3. Aug 21, 2017 at 5:43 PM
    Impressive for sure.
  4. Aug 21, 2017 at 6:35 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    I would not get drilled though, I've had disks crack from hole to hole before, and it's not fixable.
    If anything, slotted is probably your best bet.
    TheBeast[OP] likes this.
  5. Aug 22, 2017 at 5:19 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have EBC rotors that are dimpled and slotted on my wife's vehicle. Zero complaints. Haven't tried R1 though.
  6. Aug 22, 2017 at 9:02 AM
    EBC sport rotors is another option.
  7. Aug 22, 2017 at 9:04 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Powerstop is another option. I'm running the front drilled & slotted and about to throw on the rears. I love them so far and notice a huge difference with just the fronts. They are also about half the cost on Prime compared to the R1s
  8. Aug 22, 2017 at 9:05 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  9. Aug 22, 2017 at 9:07 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Just compared the pics between the two. Guess its half price since it has half the holes lol
  10. Aug 22, 2017 at 9:15 AM
    they look great too
    boardude likes this.
  11. Aug 22, 2017 at 9:17 AM
    do you guys usually change the brake pads when changing the rotors ?
  12. Aug 22, 2017 at 9:20 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I didn't. The oem pads are actually pretty decent. I have ceramic pads though for when its time. I'll probably remove the rotors and clean them too when that time comes
  13. Aug 22, 2017 at 9:23 AM
    did you notice improvement by just swapping rotors ? with the big tires I feel it doesn't brake as good than when it had oem wheels.
  14. Aug 22, 2017 at 9:32 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I noticed a big difference mostly when really getting on the brakes. Before I felt like I would put my entire weight on the brake and it would just crawl to a stop, I'm sure the 35s didn't help lol. Now it stops on a dime
  15. Aug 22, 2017 at 10:42 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    S/S lines, some new fluid, and ceramic pads would get you to stop on a hair.
    boardude[QUOTED] likes this.
  16. Aug 22, 2017 at 1:04 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I'd stick to slotted but if you must then dimpled yes drilled no
    Sefferston likes this.
  17. Aug 22, 2017 at 1:06 PM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I've had ebc and powerslot on other vehicles with no issues and solid performance improvement when paired with the right pads.
  18. Aug 22, 2017 at 4:36 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    TheBeast[QUOTED][OP] likes this.
  19. Aug 22, 2017 at 5:47 PM
    you right, it's like 50% off on ebay in their shop..LOL..did you end up buying their kit ?
  20. Aug 22, 2017 at 6:07 PM
    rons23
    Ron
    Kill Devil Hills
    Not yet, but when i go to change out brakes, that will be the kit. Make sure you go with there premier kit though.
