Rack and pinion movement is it normal?
Discussion in 'General Tundra Discussion' started by Rica25, May 5, 2018.
  1. May 5, 2018 at 12:14 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    So if you look at the center of the rack and pinion right under the splash shield does your guys move from left to right .........the test is with ignition off and vehicle on the ground move the steering wheel side to side while some one is underneath looking at the rack
