Rack with a RetraxPro tonneau?
Discussion in 'Tonneau Covers, Caps and Shells' started by Jlkinsey88, Dec 8, 2020.
  1. Dec 8, 2020 at 7:19 AM
    Jlkinsey88
    Jlkinsey88 [OP] New Member
    Jared
    2020 white tundra sr5
    So I’ve run into a problem with my RetraxPro MX bed cover. The cover is amazing have had it a little under a year and love it. My problem is I never thought I would have any need for a rack. But because of COVID I ended up losing my job and getting into roofing sales and will be needing a rack. Trying to find ways around not having to sell this cover and buying the proXR. Thanks for any info.
  2. Dec 8, 2020 at 7:25 AM
    TaquitoBandito
    Joel (AKA Bif)
    I have the XR - I believe the only difference is the rail. Have you contacted Retrax to see if you can buy a set of those separately? I just did a quick look and found these:
    https://www.etrailer.com/Accessories-and-Parts/Retrax/RTT-82381.html
    Not cheap by any means but they are out there.
  3. Dec 8, 2020 at 7:49 AM
    RobertD
    Robert
    DFW, Texas
    Could you get a rack that uses the pocket holes? The ones ontop of the bed rail that you would have to trim the plastic from covering. I know they are still exposed with my tri fold but unsure how exposed they are with your rail system.
  4. Dec 8, 2020 at 8:19 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I have a co-worker that bought the Retrax, and later bought the track rails. Pretty simple swap...just that you're out the cost of the second set of rails.
  5. Dec 8, 2020 at 8:30 AM
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    XR here as well. I went with Rhino Rack for my crossbars, but have been curious to see if there was some sort of mod to put a track capable cab-height bed rack on top for an outlander tent setup. Crossbars are supposed to hold 220# each, but I don't know what cumulative weight the tracks would hold. As you guys are saying in here, prices for all these things is cray-cray, but I was just curious if I needed to strike an arc, or if someone had something already.
  6. Dec 8, 2020 at 8:37 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    I don't know anything about your rack system but good luck with the new job! I am glad to hear that you were able to find something and keep going. I hope you sell a lot of roofs.
  7. Dec 8, 2020 at 8:43 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Yakima makes a base for their HD truck rack that works specifically with the retrax track side rails.
  8. Dec 8, 2020 at 11:24 AM
    sethconlin
    sethconlin New Member
    2018 Quicksand TRD
    I have Retrax XR with the rails, and use the Yakima Overhaul HD system with it. Spring/Summer/Autumn I have a Tepui RTT up there. Works great, solid, no shifting, easily adjustable. With the Retrax rails it's easy to remove as well.
  9. Dec 8, 2020 at 5:30 PM
    Jlkinsey88
    Jared
    Thank you for the idea and link
  10. Dec 8, 2020 at 5:31 PM
    Jlkinsey88
    Jared
    Ya I’m hoping that I won’t have to buy new rails on top of the money to buy a rack too.
  11. Dec 8, 2020 at 5:44 PM
    Jlkinsey88
    Jared
    Thank you for the kind words. Definitely hard to go from a great steady paycheck to a commission paying job. But I will overcome.
  12. Dec 8, 2020 at 5:52 PM
    Jlkinsey88
    Jared
    I know it works for the Xr but I don’t have the rails for it. Was thinking something like this may work. But looks like it might be a pain to take on and off.
  13. Dec 8, 2020 at 6:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Voodoo fabrication makes a bracket for their rack that will go around the rails. I’ve seen them used to put a rack over top of a diamondback cover (@Explorer has them on his truck) - don’t see why that same idea wouldn’t work for the retrax.
    Jlkinsey88[OP] likes this.
  14. Dec 8, 2020 at 6:26 PM
    Jlkinsey88
    Jared
    Thanks I will have to look into them
  15. Dec 8, 2020 at 8:20 PM
    Jlkinsey88
    Jared
    Anyone have any experience with this rack?
  16. Dec 8, 2020 at 8:38 PM
    NUMB LOCK
    NUMB LOCK Perpetual Member
    Northern VA
    2016 MGM TRD Pro
    Fox 3" lift, Methods, 35" A/T Baja Boss, Retrax Pro XR, Baja Designs light bar, Warn winch, Chaos Fab Shop tire carrier
    Saw a video online where the owner of the Yakima Overhaul HD was having issues with the bolts pulling up on the rails of a RetraxPro XR. Here is his video, wondering if you've ever noticed this issue with the rails and your roof top tent (RTT) installed. Wondering if he may have just over torqued the bolts...I'm honestly hoping this is the case cuz I was planning on purchasing the RetraxPro XR and the Yakima Outpost HD system for my RTT.
    https://www.youtube.com/watch?v=tXmKi5SfXHk
    splitfuse likes this.
  17. Dec 8, 2020 at 9:11 PM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
  18. Dec 8, 2020 at 9:30 PM
    RainMan_PNW
    Casey
    Clark County, WA
    NUMB LOCK[QUOTED] likes this.
  19. Dec 8, 2020 at 9:43 PM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
  20. Dec 9, 2020 at 6:17 AM
    Jlkinsey88
    Jared
    This attachment to the truck look awesome and seem like it works great. I would just have to figure out how to make it a taller rack as I will need it to be above the can for a long two story ladder. Definitely nice to see someone has put a rack with the Mx thank you.
  21. Dec 9, 2020 at 6:33 AM
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
  22. Dec 12, 2020 at 11:54 AM
    Jlkinsey88
    Jared
  23. Dec 12, 2020 at 5:38 PM
    TaquitoBandito
    Joel (AKA Bif)
    Do you have a CrewMax and do you happen to live in Texas?
  24. Dec 13, 2020 at 6:59 AM
    Jlkinsey88
    Jared
    Yes and yes
  25. Dec 13, 2020 at 9:17 AM
    TaquitoBandito
    Joel (AKA Bif)
    I may have a solution for you but it might be a pain in the ass. I ordered a Retrax MX Pro in late 2016 for my 2017 Tundra. It had a dent in one of the slats that didn't affect it's use but the sent me a replacement canister anyway.
    I have the one with a dent in it boxed up on a shelf in my shed. What I'm thinking is that maybe you can offset the $400 cost of the XR tracks by selling my canister with your MX tracks to somebody with a crew max who would want an amazing deal on a Retrax for their work truck or something.
    It's yours if you want it and at least you could cover the cost of the the XR tracks. I live in Central Texas between Bastrop and La Grange.
  26. Dec 23, 2020 at 2:21 PM
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    If anyone is looking for a retrax bed rack, I have a uptopoverland mid height truss for sale. I assembled it but never installed it on the truck and just ordered a ATO atlas camper so won’t be using it. . PM for details if interested as I don’t have enough posts to sell yet.
  27. Jan 7, 2021 at 3:32 PM
    sethconlin
    2018 Quicksand TRD
    Sorry, just saw this question. I haven't taken mine off since install, however, judging by how much he rounded that nut on the rear tower, I'd say definitely consider the source here. More than likely an over torque situation. The yakima towers definitely sit on the rail and transfer the load through it, the bolts are there to simply stop the rack from sliding forward and back, and counter any lift that may be associated with the load. I will endeavour to check the rails in the near future.
