Radiator Fan Clutch
Discussion in '1st Gen Tundras (2000-2006)' started by DIY Dude, Apr 21, 2022.
  1. Apr 21, 2022 at 8:58 AM
    DIY Dude
    DIY Dude [OP] New Member
    Carl
    2004 Tundra 4.7liter 4WD Texas Edition
    2004 Gray Tundra 4.7 Texas Edition 4WD
    My 2004 tundra overheats sometimes. How do I tell if the fan clutch is working properly or not?
  2. Apr 21, 2022 at 9:04 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    With the engine off, how far does the fan spin when spun by hand?
  3. Apr 21, 2022 at 9:15 AM
    DIY Dude
    Carl
    It only turns a little more than 1/4 rotation....
  4. Apr 21, 2022 at 9:21 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Thats about how mine does. I dont think its in spec, but mine doesnt overheat.
    ever cleaned the fins on your radiator? Like spray through with a waterhose?
    frontward and backwards, make sure the fan shroud isnt full of leaves or whatever.
    des2mtn and Mogo Gogo like this.
  5. Apr 21, 2022 at 9:28 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I was dealing with overheating occasionally at low RPMs and suspected the fan clutch was going out and not engaging properly, as the temperature would come down when I started moving. I had also read that the fan clutches have limited life.
    At 165k I replaced it with OEM, along with my thermostat, water pump, radiator and t-belt. Since I did so much at once, I can't say for sure the fan clutch was the fix. Putting a rubber door stop between the crank and idler pulley helps for tightening/ loosening the 10mm bolts on the fan FYI.
    My engine fan on the truck will do more than a 1/4 turn with the new fan clutch. Trying to turn the old clutch by hand (not on truck/ fan), there is a good amount of resistance.
    Mogo Gogo likes this.
