Radiator mounting bolt torque?
Discussion in '1st Gen Tundras (2000-2006)' started by bigdans, Jun 25, 2022.
  1. Jun 25, 2022 at 8:06 AM
    bigdans
    bigdans [OP] New Member
    Daniel
    2005 Tundra SR5 double cab TRD off road 2wd
    My 2005 SR5 DC 2wd v8 developed a pin hole type leak in the upper tank. I decided at 17 years old and 126,000 miles to replace it with a Denso OEM radiator, Gates hoses, and as a plus a Gates serpentine belt. Pretty easy. 5 clamps, 10 bolts , coolant drained and filled with red, $320 on Amazon and 2 hours later, done. Never found a torque spec for the four fan shroud bolts or four radiator mounting bolts. I’d rather know and tighten appropriately. Anyone?
  2. Jun 25, 2022 at 3:11 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Snug. Works for most non-critical torque applications
    bigdans[OP] likes this.
  3. Jun 25, 2022 at 4:03 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Agree....those type bolts for me, I get to the point where I have to help the ratchet and add ~1/4 turn....1 o2 ugga dugg's
    from 2005 FSM....
    tvpierce and bigdans[OP] like this.
  4. Jun 25, 2022 at 5:27 PM
    bigdans
    Daniel
    Thank you!
