Ran out of Gas
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra Man 05, Mar 28, 2022.
  1. Mar 28, 2022 at 7:03 AM
    Tundra Man 05
    Tundra Man 05 [OP] New Member
    2005 Tundra
    I just ran out of gas but my gauge showed that I had at least an eighth of a tank left, well above the empty mark. The low fuel light never came on. I put a half-gallon of gas that I had in the bed of the truck and it started right up. Why doesn't the light work and do you think this is a gas sending issue?
  2. Mar 28, 2022 at 7:10 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    I have random readings like that on my 18. Sometimes it runs dry at just under a quarter tank, other times it will go way below E and still get me home. I think its a voltage issue in the sending unit
  3. Mar 28, 2022 at 7:10 AM
    I haven't had the tank open on my truck yet, but many vehicles use a simple float system (foam float on an arm or post, typically) to track the level of gas.
    When your tank isn't reading correctly, one of three things is usually true:
    - The float is stuck, and percussive slapping of the tank may free it up, same with a fill-up of the tank
    - The sending unit that the float interacts with is bad and needs to be replaced (sometimes it's integrated w/fuel pump, so full pump replace req'd)
    - The dash gauge or ECU isn't properly reporting or interpreting (respectively) the resistance on the float's sensor itself
    The obvious solution here is a full tank of gas to see if the needle goes higher or not, then note your mileage, and watch to see if you hit half a tank within 125-150 miles.
    If you have a scan tool that can read the resistance sensed by the tank fill sensor, that can speak volumes also.
    Not sure if this helps?
    5N0W808 and des2mtn like this.
  4. Mar 28, 2022 at 7:39 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Possibly burned out ?
    Have you changed the bulbs to LED or are they still incadescent ?
  5. Mar 28, 2022 at 7:39 AM
    Radarninja
    Radarninja New Member
    Ryan
    Ca
    Lol a full tank of gas is the most expensive option lol
    MachSlow, JODOOR, eccracer104 and 5 others like this.
  6. Mar 28, 2022 at 7:45 AM
    I don't consider it an expensive option. If you drive your vehicle, you had to put gas in it anyway, so it's not costing much of any added money by the mile when fuel prices are stable for more than a few days.
    5N0W808 likes this.
  7. Mar 28, 2022 at 8:14 AM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Just had this happen on my 2008. Ran out with 1/4 still showing on the gauge and no low fuel light. Wife drives this truck now, so when I borrowed to visit my dad, truck shut down a block from his house. As a long shot, I called my dad had him bring down about 3/4 of gallon that he had at the time. Truck started right up and off to the gas station I went. Put 25.1 gallons in the tank. Got home and told the wife we have a bad sending unit and that she needs to re-set trip A on every fill up and that she better be looking for fuel when she gets close to 300 miles.
    Not sure how long it's been non-functioning as I would always fill up at or above 1/4 tank when I was driving. My wife, on the other hand, ALWAYS waits for the light.
  8. Mar 28, 2022 at 8:38 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Had the same thing happen on my 08'. My wife was driving thru morning traffic in Austin (I-35) when truck died. She was able to pull off to slight shoulder on left side of interstate before an emergency vehicle pulled up and offered a few gallons of gas. I don't believe the low fuel light was even on, had 1/4 tank when she left house. Anyway, we're really lucky that she didn't get in an accident, had our 8yr old (at the time) in the back seat. I took truck to my local mechanic, and he confirmed that there was a bad sending unit in fuel pump. Had it replaced and never happened again, although we did try to keep tank at 1/4 and above since then. Traded the 08' for my 16', which happened to have another bad fuel pump on. Used TSB-0166-19 for the 16'.
  9. Mar 28, 2022 at 8:39 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I believe OP has an 05 with the newer cluster so there's no incandescent to burn out.
    shifty` and BubbaW[QUOTED] like this.
  10. Mar 28, 2022 at 8:40 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Yeah, really. It would be cheaper to have a shop replace the fuel assembly than fill the tank. :rofl:
  11. Mar 28, 2022 at 9:00 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Good to know....suppose it then could be LED burned out and if not, the troubleshooting gets a little more intense.
    MS22 likes this.
  12. Mar 28, 2022 at 3:36 PM
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    should probably just trade it in for a KTM
    des2mtn and Radarninja[QUOTED] like this.
  13. Mar 28, 2022 at 4:19 PM
    Radarninja
    Ryan
    Ca
    I agree, this is mine
    FirstGenVol likes this.
  14. Mar 29, 2022 at 7:38 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    I'm paranoid and don't trust fuel gauges. When the gauge gets to half, I fill it up. On a 22 yr old truck, I can't chance the float and sender are working correctly. Hope you solve your problem.
    GODZILLA likes this.
  15. Mar 29, 2022 at 8:17 AM
    OP hasn't been back since posting. We can only assume that he/she is currently stranded without fuel somewhere and will perish. Let this be a lesson to fill your tanks at the halfway mark, or reset your odometer and fill up every couple hundred miles.
  16. Mar 29, 2022 at 8:30 AM
    Schcoman
    Humboldt Co. CA
    None
    That's what I used to do with my old '89 Ford Ranger. The gauge would read full until it was dry. Fill, set trip odo, no problem. I live in a very rural county. I'm not going to get stranded for a few gallons of fuel.
    GODZILLA[QUOTED] likes this.
  17. Mar 29, 2022 at 2:11 PM
    tokolosh
    J
    SF Bay Area
    new driver
    I know, definitely the kinda bike a db such as you would ride :p
  18. Mar 29, 2022 at 2:42 PM
    Radarninja
    Ryan
    Ca
    You tryin to get my digits or what?
    It’s working lol
  19. Mar 29, 2022 at 2:45 PM
    Gotta ask, who is Dr. Kurtis and why do you dislike them? Don't break forum rules on politics or something though. If it's like that, just PM me.
  20. Mar 29, 2022 at 3:16 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I tried looking up drkurtis, too. Lol
  21. Mar 29, 2022 at 3:18 PM
    Radarninja
    Ryan
    Ca
    Lol, he’s my buddy. We had these made for his graduation. He hates being called doctor.
    bmf4069, FirstGenVol, des2mtn and 2 others like this.
  22. Mar 29, 2022 at 3:19 PM
    That's awesome! :thumbsup:
  23. Mar 29, 2022 at 4:11 PM
    tokolosh
    J
    SF Bay Area
    new driver
    sigh, a guy can hope
