Random beeping becoming an annoyance.
Discussion in '3rd Gen Tundras (2022+)' started by Silver '23, Jun 5, 2024.
  1. Jun 5, 2024 at 1:47 PM
    Silver '23
    Silver '23 [OP] New Member
    2023 Tundra Limited 5.5' Crewmax.
    N-Fab Nerf Step RS Running Boards. BAKFlip MX4 Tonneau Cover. Husky Weatherbeater Floor Liners.
    I'm currently getting random beeps, and it's pretty damn annoying. I'll get 7 randomly spaced single beeps over a 20 min car ride and then nothing for the next 4 days. Sometimes the beeps are every few seconds and other times there's multiple minutes in between. There's no noticeable change between time of day, weather, how close I'm following the car in front, etc. It'll happen when I'm doing 60 on the highway or 28 on a deserted back road.
    I did search the site prior to posting and did see some experience beeping without any dash warning lights, as is my case, attributing it to the front bumper sensors after a replacement or aftermarket add on. My bumper is fine. I haven't done anything to it, have not replaced it, have not hit anything and there are no scratches implying someone may have tapped and run when I was parked.
    But if it is a front bumper sensor issue, that could make sense as no lights illuminate during the beeps and all my dash levels are at correct spots/temps, etc.
    I did take it to the dealer 2 weeks ago, but they were no help as nothing was reading bad and the best they could offer would be for a tech to take it for a ride to simulate it into happening. Because it's truly random and nothing pops up to notify, I wasn't sure what that would even accomplish other than me not having my truck all day.
    Any thoughts.
  2. Jun 5, 2024 at 2:14 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Jun 5, 2024 at 2:14 PM
    ArcticFox
    ArcticFox New Member
    California
    No matter how silly it sounds, check if your left knee/leg is not hitting the seat memory recall button on the driver's door. It happened to me—random beeps out of the blue.
    Once I found the cause, I 3D-printed a flip cover to prevent touching the buttons.
    Silver '23[OP] and pwpblue like this.
  4. Jun 5, 2024 at 2:18 PM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    Even though it's not throwing a "Brake" warning when it beeps, you could try just turning off the pre-collision system while you are driving and see if anything changes. That might help in determining if it's the front sensors or not.
  5. Jun 5, 2024 at 2:23 PM
    SpilledTheSalt
    Oregon
    This kinda thing reminds me of the remote controlled fart boxes. We hid one under a copier at work years ago. Watching people walk by and then setting it off was hilarious. Even the copier service company was called out to try and figure out where the weird noise was coming from.
  6. Jun 5, 2024 at 9:01 PM
    BossDawg24
    BossDawg24 New Member
    Mark
    Cumming, GA
    2023 Tundra Capstone Blueprint, 2017 1794 Barcelona Red
    None
    I believe you have a setting that alerts you when you are a certain amount over the speed limit enabled. Can't remember exactly what's it's called, but I remember the same thing when I first got my Tundra. It's in the menu settings on the cluster. You can set it to vibrate, give an audible beep, or display it as a red line around the little speed limit sign on the dash. You have the option to have it alert you when going 1-5 miles over the posted speed limit. It is under the RSA menu I believe.
    Go to that menu, hold it for a few seconds and it will give you options to get an audible beep, a vibration, or no notification
  7. Jun 6, 2024 at 3:56 AM
    JayDee
    JayDee New Member
    If you have the OEM dash camera it will beep (and start recording) whenever the truck experiences a significant bump.
  8. Jun 6, 2024 at 8:18 AM
    Silver '23
    I'll be damned. This forum is awesome! I'm almost 99% positive this is the issue. At 6'4 & 255, I'm a large guy, so it's not noticeable to me while driving that my knees, elbows and shins are always resting against something as it's been that way in trucks since I was 18, lol.
    Now that you've brought it to my forefront, yes, my left knee basically rests on this area and yes, when I push the buttons while in motion I get the beep!
    Do you have any photos on the 3D printed fix you used? Thanks again man.
    Blufin and Tundrastruck91 like this.
  9. Jun 6, 2024 at 11:41 PM
    ArcticFox
    California
    There you go - it's blue because I already loaded midnight blue PETG into the printer. And as with many temporary fixes - it stayed like that. It could look fabulous in red to match TRD Pro accents (shifter and steering wheel).
  10. Jun 7, 2024 at 1:25 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Blufin likes this.
  11. Jun 7, 2024 at 5:42 AM
    OutgrownTacoma
    OutgrownTacoma New Member
    Taylor
    Too Many Tacomas
    Great solution!
  12. Jun 7, 2024 at 1:54 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    Ha. Well done and nice fix.
  13. Jun 7, 2024 at 5:12 PM
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    Now you just made me want to try this... :cookiemonster:
