Random quick noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by FarmerDan1008, Mar 11, 2020.
  1. Mar 11, 2020 at 6:22 PM
    FarmerDan1008
    FarmerDan1008 [OP] New Member
    Danny
    2020 Limited TRD OR 4x4 Crewmax
    I get a random noise after I drive about 50 feet or so every time I start it up. I only have 250 miles on it and its 4x4, should i be concerned? I figure it was just a normal thing but it happens every time I start and move
  2. Mar 11, 2020 at 6:27 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    That’s perfectly normal - ABS self check.
  3. Mar 11, 2020 at 6:27 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 65mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    It's the ABS doing a check. It is normal and is usually masked by the doors automatically locking at the same time. Your door lock setting may be different than default allowing the ABS check to be more readily audible.
  4. Mar 11, 2020 at 6:28 PM
    FarmerDan1008
    Danny
    Perfect thank you, I figured someone would know about it on here
