Ranges for setting up temperature gauges
Discussion in '2.5 Gen Tundras (2014-2021)' started by AndrewSmith, Sep 5, 2023.
  1. Sep 5, 2023 at 5:26 AM
    AndrewSmith
    AndrewSmith [OP] New Member
    Thornhill, Ontario
    2021 Sequoia Limited
    Hello
    I finally set up an android app with the custom PIDs needed to read the transmission temperatures.
    Now I'd like to set up the gauges in the app so that the needles show something useful.
    Are there generally accepted ranges for the following?
    * Casual operating temperature range.
    * Heavy load of some kind, but still fine range.
    * Getting close to danger, get ready to stop range.
    * Turn off the engine right now number.
    I'd like to have a set of these for the engine, transmission pan, and transmission @TC temperatures. I looked but couldn't find them.
    Thanks in advance.
  2. Sep 23, 2023 at 8:24 PM
    AndrewSmith
    Thornhill, Ontario
    Are these numbers completely unknown?
  3. Sep 23, 2023 at 8:59 PM
    Well, the high temp alarm comes in at 304*F if I remember correctly.
    Personally, I would be concerned at anything close to 265-275*F
  4. Sep 23, 2023 at 11:57 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    If I were going to set a low temp I'd go with anything under 100, under 100 the torque converter will purposely not lock in order to heat up the fluid. After 100 it will lock up normally. Normally operating temperature for a transmission with a cooler is around 185-195 unloaded since the thermostat opens around 185. As far as a high temp @ColoradoTJ touched on that above, by the time the high temp light comes on your fluid is going to need to be replaced so I would definitely set it below that 304 number. Maybe set the operating range 185-250 and anything over that in the high range?
    ColoradoTJ likes this.
  5. Sep 24, 2023 at 12:41 AM
    That's a good point on low temperature. I have to block air flow my trans cooler in the winter to maintain 110* if not towing. OP, note I have a different model truck, so you may not experience these conditions.
    Joe333x[QUOTED] likes this.
  6. Sep 24, 2023 at 1:56 AM
    Joe333x
    Joe333x Member
    Boston
    Should not experience that with a Tundra unless the thermostat is pinned open in the winter. Does your 3500 not have a thermostat?
    Johnmatrix likes this.
  7. Sep 24, 2023 at 7:48 AM
    Nope.
    The factory transmission cooler is quite a bit smaller and would maintain 120-180* pretty regularly. I installed a PPE trans cooler that is 66% bigger. I also installed a PPE oversized Allison pan.
    Why did I do that?
    -Truck/transmission is tuned, so the transmission needs more holding power. The factory trans line pressure drops to around 80 psi for better fuel economy. This does nothing for trans long term reliability. During shifts the line pressure would go up to 200-250 psi depending on power being used/boost pressure. With the trans tune and higher line pressures after 8 lbs of boost, line pressure is raised to max. This causes extra heat (approx 30-40*F). The extra HP also causes some heat (approx 10-20*F).
    The new pan and cooler brought those temps back down to normal factory temps with all the benefits except for the winter.
  8. Sep 24, 2023 at 8:00 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
  9. Oct 5, 2023 at 5:55 AM
    AndrewSmith
    Thornhill, Ontario
    Thanks everyone. I'm going to tow my big trailer for a couple of days on the weekend and will try with the following ranges:
    <180 cold
    180-250 green
    250-280 orange
    >280 red
    There aren't any mountains around here, and it's not crazy hot these days but hopefully this will give me some useful info.
    Without the ranges it's very hard to remember when the temperature got up to what.
  10. Oct 5, 2023 at 6:57 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Have you added an air to oil cooler? Have you been monitoring temps so far? Are you monitoring TC and pan temps?
    Main thing to note is when the TC temps are significantly above pan temps, TC is unlocked and creating quite a bit of heat. If you have no cooler, pan temp warms up quickly. It's interesting if you do have a cooler, the TC output seems to flow right into the thermostat so it will open and pan temps will sometimes even cool more as the fluid goes through the cooler.
    Point is, keep the converter locked when you can, especially on long climbs. S4 locks up the converter quicker than keeping it in drive, even when in drive with the tow mode on.
  11. Oct 9, 2023 at 8:12 PM
    AndrewSmith
    Thornhill, Ontario
    Came back from my trip today, paid attention to the temperatures. Both at the torque converter and the pan.
    Looks like after a couple of hours of towing on relatively flat ground: a low but consistent slope up will bring the TC temperature to 260F. Engine braking doesn't seem to have any effect on the transmission temperatures.
    Makes me wonder what they were when I pulled this trailer kilometers up without any breaks in California. I guess they didn't reach 305F because I didn't get any overheat warnings.
    No, I don't have a cooler. It's a significant investment and I'd need to see the temperatures get closer to the red line before I go for it. Seems like most here would agree 280F is around where the red line starts. But there are no mountains in Ontario to test it on.
    I could see the two temperatures stay the same in S4 when towing flat, but not when climbing - the gear selection seemed to make no difference in that case. And the engine turns too fast for my liking in S4 when going over 80km/h.
    _none_ likes this.
  12. Oct 9, 2023 at 8:55 PM
    Joe333x
    Joe333x Member
    Boston
    Its definitely not cheap to add a cooler when you do it the right way and use OEM parts and a quality mount and radiator like the @Genuine Cooling Systems but my rational was that adding a cooler is significantly cheaper than replacing a transmission and something I can do myself. The temperature differences even when not towing is significantly lower.
  13. Oct 10, 2023 at 5:49 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    What you are noticing though is the temps go up quickly but are VERY slow to go down.
    Just for reference, i went from the same setup as you, running low to mid 200s pan temps just during normal driving. i installed a giant cooler (costs just as much as installing a small cooler...) and now pan temps do not go above 194F even when towing. With the cooler, you will notice that when the TC unlocks, TC fluid output temp goes up, but that fluid opens the thermostat which causes that fluid to get cooled before it hits the pan. When im on the highway, in 6th gear and the TC unlocks up a short rise, my pan temps DROP to the mid 180s (due to the open thermostat). Get back on flat ground, TC locks, thermostat closes up mostly and my pan temp rests around 192-194F. Do what you want, it's your truck, but if you bite the bullet and spend a few hours installing a cooler the difference is night and day.
