RCI: great skid, lousy hardware
Discussion in 'General Tundra Discussion' started by AK 6.7PSD Replacement, Oct 5, 2019.
  1. Oct 5, 2019 at 8:10 AM
    AK 6.7PSD Replacement [OP] New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    I installed an RCI skid plate 4,000 miles ago at the beginning of the summer (granted I’m in the swamps of Charleston SC). You’d think the hardware would be stainless. Anyway, only a $3 fix at Ace Hardware. Should I get stainless or brass or...?
    Black Wolf likes this.
  2. Oct 5, 2019 at 8:39 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Granted that it’s an easy fix, I would call them to replace it some they have the stainless again
  3. Oct 5, 2019 at 9:23 AM
    AZTundra
    Paul
    Phoenix, AZ
    Id go for some stainless and call it good.
    BravoDeltaRomeo likes this.
  4. Oct 5, 2019 at 9:32 AM
    If I recall correctly RCI had a fastener supply issue at some point and will send you the proper quality fasteners. I'd call them.
  5. Oct 5, 2019 at 9:42 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Brass? I think you mean gold colored zinc plated?
    Either will be fine. One will probably be a few more cents than the other.
  6. Oct 5, 2019 at 9:50 AM
    15whtrd
    15whtrd Mr. Blonde
    Yup @Pinay had missing hardware. Im sure they will send it, but you know how that goes. You’re under there with your old skids removed and ready to install, only to find out it’s missing stuff. By that point you want it on LOL. Quick trip to the hardware store fixes that. It requires some type of washer above the crossmember to hold the back of the skid plate up. Large fender washers will do the trick but they do bend a little as you tighten them. I bought Monets skid plate and left her hardware for the trans skid. I had to source some stainless carriage bolts and decided to use some flat stock for washers instead of what was available at the hardware store. Big fat thick washers are surprisingly hard to come by LOL.
    Here’s what I used in the red.
    gosolo, Pinay and Black Wolf[QUOTED] like this.
  7. Oct 5, 2019 at 9:57 AM
    15whtrd
    15whtrd Mr. Blonde
    I wouldn’t use brass. Phillips head, flat head or Alan will definitely strip easily. In plumbing we have to use brass coarse thread screws to hold down the closet flange for code. They tend to be a one time use LOL. I found that I have to pre-drill just so I can get them to go in all the way. And sometimes they snap anyways. I would use stainless if I can find it in the right size. Although zinc is fine, it would take a long time to rust out. Funny thing, at Home Depot it lists zinc fasteners for “indoor use”.
  8. Oct 5, 2019 at 10:00 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    That’s exactly what happened. Missing some washers, got to point of install and quick trip to Ace. Just ruins the flow, just wanted it on and done.
    15whtrd[QUOTED] likes this.
  9. Oct 5, 2019 at 10:02 AM
    It's always good to check shipping box contents for any missing parts. Things happen which sucks, at least you can call right away and get any missing items sent out instead of being caught in the middle of an install with parts missing.The fastener issue with RCI was not that they didn't have the fasteners to ship, the problem was having to ship out fasteners not up to their quality specs. Was a temporary thing and have sent out replacement fasteners to who needed them.
    Pinay and 15whtrd[QUOTED] like this.
  10. Oct 5, 2019 at 10:04 AM
    What's funny is I had extra mounting washers shipped with my skid....heh...heh
  11. Oct 5, 2019 at 10:06 AM
    15whtrd
    15whtrd Mr. Blonde
    You probably got Monet's hahahahaha
  12. Oct 5, 2019 at 10:10 AM
    15whtrd
    15whtrd Mr. Blonde
    That is something I’ve learned through the years, check the package contents to the hardware list.
    DZ_ and Black Wolf[QUOTED] like this.
  13. Oct 5, 2019 at 10:54 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I have learned that every purchace from RCI means a trip to the hardware store and foot the bill yourself.
  14. Oct 5, 2019 at 11:00 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s a bit sad. They make a great product so it’s obviously not the fabricator or the initial design that’s the problem. But who ever decided to cheap out on the hardware, dropped the ball. What’s the point of having a great product if it’s not mounted properly. Yeah the hardware gets it done but it should reflect on their product. Almost like it’s a second party that sends out the hardware.
    Pinay likes this.
  15. Oct 5, 2019 at 11:02 AM
    The washers on the back are welded—not a concern. I’m not messing with shipping back and forth. Stainless from Ace it is.
  16. Oct 5, 2019 at 11:14 AM
    TheBeast The Beach
    same here...
  17. Oct 5, 2019 at 11:16 AM
    TheBeast The Beach
    couldn't find stainless steel at HD so I got galvanized. let see how long it lasts.
  18. Oct 5, 2019 at 11:33 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    What I heard is RCI gets the hardware bagged up already and a while back they had bolts or washers missing. Hopefully it’s been corrected.
  19. Oct 5, 2019 at 11:39 AM
    Tacogrande
    Jeremy
    Home depot sucks. I go to Fastenal or order from McMaster Carr.
    DZ_ likes this.
  20. Oct 5, 2019 at 11:47 AM
    agree—Home Depot and Lowe’s have a large selection of random crap, but I’ve slowly learned that the local hardware store—and especially Ace Hardware—has everything I need, are infinitely more helpful/customer friendly and are much easier to get to/through/out of and back on my way. Well worth the 5% price increase if you ask me!
    DZ_, RangerBP, TheBeast and 2 others like this.
  21. Oct 5, 2019 at 9:34 PM
    TheBeast The Beach
    I'm with you here. ACE is customer friendly. Home Depot, most of them run away from you :)
    Pinay likes this.
  22. Oct 5, 2019 at 10:17 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This is exactly what I got. Bags of hardware were still sealed but incomplete. I had sufficient stainless steel bolts on my shelf to replace it all and make it match.
  23. Oct 5, 2019 at 11:10 PM
    oogabooga289
    oogabooga289 New Member
    Anybody replace the screws with SS and have a part number and/or thread specs on the replacement?
  24. Oct 6, 2019 at 3:54 AM
    this is what you need for the oil filter door
  25. Oct 6, 2019 at 8:37 AM
    oogabooga289
    Thanks!
  26. Oct 6, 2019 at 8:43 AM
    plus a washer...
    oogabooga289[QUOTED] likes this.
  27. Oct 6, 2019 at 9:10 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    For anyone using the diff drop spacers who actually bash their skids on rocks, I’d suggest replacing those spacers with wider ones. They’re too small and just press into the truck. That should be flat and not concaved in. It ruined the threads and I couldn’t even get the skid off.
  28. Oct 6, 2019 at 10:03 AM
    oogabooga289
    Holy crap. Is that a crossmember?
  29. Oct 11, 2019 at 10:26 AM
    UPDATE:
    On a whim I called RCI and explained the concern. No dithering—they fully-owned a bad batch of hardware and offered to send out a new batch today which I accepted. Couldn’t really ask for anything more so I’ll still like their products. I’d imagine most businesses would like the opportunity to make things right (which they did).
    15whtrd likes this.
