Ready fo new shoes! 285/75/18
Discussion in 'Wheels & Tires' started by ackthresher, Jul 2, 2024.
  1. Jul 2, 2024 at 2:16 PM
    ackthresher
    ackthresher [OP] New Member
    Jamie
    2017 cement crew max tundra pro
    Need new tires and ready to pull the trigger.i am installing Wescott design front 1.5 lift and coach builder +3 shackles in rear!I also have a set of scs ray 10’s in black!!!I am leaning towards the Toyo at 3 285/75/18! Any issues that I should be concerned about?thank you!!
    ZappBrannigan and Tripleconpanna like this.
  2. Jul 2, 2024 at 7:49 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Falken Wild Peak.............
    BR73 and ZappBrannigan like this.
  3. Jul 2, 2024 at 9:49 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I like my wildpeaks, they are quite a bit better than the K02’s I had in the wet. I have no experience with the Toyo’s however.
  4. Jul 3, 2024 at 6:31 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Kenda Klever RT in 285/75/18 here. Love the tires so far. I had Toyo AT 2 in 295/70/18 previously and they were ok. The Toyo AT 3 has a much better design and tread pattern than the AT 2. I think you will be very happy with them.
    Silver17, dagsom and Ceezurin like this.
  5. Jul 3, 2024 at 6:41 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I run 285/75s on the stock +60 offset wheels. They fit with that offset with no other mods except removal of the front air spats. If tires were any bigger in height or width or if I has wheels with less positive offset I would have rubbing that would need to be addressed.
    Your wheels will have less positive offset, so you will probably need to lose the mudflaps. Will need to remove the front air spats at front bumper/wheel well. May need to mess with inner fender plastics and or space the front bumper, depending on how aggressive the wheel offset is. If you have the stock skid plate, may need to trim the ears off that as well to avoid rubs.
  6. Jul 3, 2024 at 8:45 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    I am at a +25 offset and did rub the factory skid before I trimmed off the ears. I did have to remove the little mud flap and also had the take a heat gun to the front finder liner. Other than that not too bad at all.
  7. Jul 3, 2024 at 8:52 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I have 285/75/18 Toyo AT3 on BBS Pro (+60)
    ~2.5" lift
    JBA UCAs. ~4° caster
    Fitment mods removed front flap, added ½" bumper spacers. Re-molded rear portion of fender liner. Folded in skid plate. I rub on front sway, both sides before full lock. Considering spacers.
    Every fitment will be a bit different and rather dependent on alignment.
  8. Jul 3, 2024 at 9:18 AM
    Ceezurin
    Ceezurin New Member
    Franco
    El Paso, Texas
    2019 Cavalry Blue Limited Crewmax
    Bilstien 5100 all 4 corners, Toytec shackles, mbrp full exhaust single exit, husky liners, diode dynamics interior and exterior lighting
    I really like the look of these and have heard great things. Do you know if they’re available at discount tire?
  9. Jul 3, 2024 at 10:10 AM
    2020cement_tundra
    2020cement_tundra New Member
    Nick
    SC
    2020 tundra
    Check out the Wildpeak rt01’s. I’ve got about 4K on them and zero complaints.
  10. Jul 4, 2024 at 6:14 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    Ceezurin[QUOTED] likes this.
  11. Jul 4, 2024 at 9:34 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    The Toyos and Falkens in this size are fairly heavy at upper 60 pounds (68lbs+). The Ray10s are pretty light at 27lbs to offset that a bit. The Duratracs in this size are 62lbs to save some weight/mpg/handling.
  12. Jul 4, 2024 at 9:48 AM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Not sure of your use case, but I went to the Geolandar X-AT in 285/75 on stock +60 wheels on the last go-round. Love them.
    First time on a yokohama tire, but they are night and day for a smooth ride after getting nearly beat to death on late-in-life Duratracs.
  13. Jul 4, 2024 at 10:33 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I have about 10k on a set of Toyo AT3 and am very happy with them. They are surprisingly loud, but not obnoxious. The winter traction is excellent. They are wearing very evenly and holding up very well. I would buy them again.
    DZ_ likes this.
  14. Jul 4, 2024 at 10:43 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    On my 2nd set of LT285/75R18 Duratracs. I think these trucks should come with this tire. I have no noise or ride quality issues; I run them at 38 psi and rotate religiously. I got 47k miles out of the first set. With the way I use my truck (lots of off-roading and unmaintained service road driving), I didn’t expect to get nearly that many miles out of them.
    I will probably run the Duratrac RT next. Same thing but with Kevlar and more siping. I have those on our LX in standard load 275/60R20 size.
    Duratrac:
    vs Duratrac RT:
    CaptRussia253 and JLS in WA like this.
  15. Jul 4, 2024 at 10:43 AM
    40man
    40man New Member
    I've run Falken AT3s on numerous rigs and just put AT4s on my 16 Land Cruiser. Love them. Before that, the Cruiser had the Toyo OC AT3s, they wore much faster, were worse on ice and were a bit louder than the Falkens. Still overall a decent tire. I also got about 1 mpg better with the Toyos. The Falkens, in all sizes, tend to be heavy.
  16. Jul 5, 2024 at 4:28 PM
    ackthresher
    Jamie
    All you guys are great!!!thanks for all the feedback ,it helps!!!!!
  17. Jul 5, 2024 at 4:33 PM
    ackthresher
    Jamie
    Shackles have arrived
  18. Jul 5, 2024 at 4:42 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I've been going around on tires too. Just got my new wheels so waiting for Monday morning for tire shop to open.
    My decision is either the BFG HD AT or the Toyo Trail RT. I've had Toyo's for years and really prefer them.
    Usually I run the Toyo Mt on my Land Cruiser but it sees the worst that back country can offer but I never worry
    about my tires failing. So probably will fall on the Trail RT just as less aggressive but should work well. The new BFG KO3 tires aren't available in Canada yet, at least not here anyhow. I have a friend up north running Duratracs but they don't seem to get the miles, as far as I can tell. There is a guy running the Trail RT's on his 2010 RCSB, which is what I've got and that's probably the way I'll go
  19. Jul 5, 2024 at 5:54 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Nothing wrong with the Toyos they are just expensive.
    They were my top choice but ended up going with my 2nd choice of the Mickey Thompson Baja Boss AT.
    With the $100 mail in rebate at the time I saved about $500 on the set over the Toyos.
    I don’t regret the Mickeys at all they are an outstanding tire!
  20. Jul 6, 2024 at 7:57 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Still loving my 285/75-18 Wildpeaks. The only thing I’d like to try different would be the new 35x11.5-18 LRC Wildpeaks. Nearly identical dimensionally, but a lighter tire.
  21. Jul 6, 2024 at 8:05 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Up here they are all expensive! BFG cost most. Toyo's aren't as expensive as Mickey T's by a long shot.
    ZappBrannigan likes this.
  22. Jul 6, 2024 at 8:07 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I've had the RT Trail since September, they replaced two back to back sets of Trail Grapplers, and I am not liking their wet road performance.
  23. Jul 6, 2024 at 8:15 AM
    Terndrerrr
    Music City
    6UR-FE
    I’d love to find some lighter weight skinny 35s. That’s what I think of 285/75s and 35x11.5; they’re about the same size. But everywhere I look, load range C ends up weighing about the exact same as load range E tires.
    285/75R18 Duratrac RT: 62.46 lb
    35x11.5R18 Wildpeak A/T4W: 62.6 lb
  24. Jul 6, 2024 at 8:44 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Going up from C to E is the price of security to me. I can live with a rougher ride.
  25. Jul 6, 2024 at 8:49 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Those are different tires from different manufacturers. Falken Wildpeaks are heavy, regardless of size. They’re just heavier than a lot of others.
    If you look at the 35x11.5-18 LRE and the 285/75-18 LRE Wildpeaks, you should see that the LRC is a few pounds lighter per tire.
    Absolutely nothing wrong with LRE! But, both options can carry well over what our trucks are rated for.
  26. Jul 6, 2024 at 9:08 AM
    Terndrerrr
    Music City
    6UR-FE
    Yes, Falkens are notoriously heavy.
    My point is, I can’t find anything lighter than my Duratracs in a comparable size even in load range C. I have no ride comfort issues with my current tires, and I appreciate the E load sidewalls when I’m aired down to 18psi. I would give some C load tires a chance if I could save weight by doing so.
  27. Jul 6, 2024 at 10:29 AM
    Jackstraw
    Jackstraw New Member
    2020 DC TRD Off Road
    According to the DT website, the 285/75/18 Falken AT4s weigh 78lbs for E load. That’s a big difference from the 35x11.5 C load.
    Both loads are 60k, AT and 3PMS rated.
  28. Jul 6, 2024 at 10:55 AM
    Black
    The Wildpeaks are also rock chuckers!!! I am on gravel constantly and they picked up gravel like crazy and I was launching gravel for a 1/4 every time I hit the pavement. When I had them.
    The Mickey Thompsons rarely pick up any gravel.
    I went with the C instead of the E. The tires are light and with MT’s sidewall construction/technology I am not worried about them.
    Terndrerrr[QUOTED] likes this.
  29. Jul 13, 2024 at 8:21 AM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
    been watching this thread for a while. I am also considering 285/75/r18's Thank you for all the info! Seems like a +25 offset would rub the rear of the wheel well and the bumper. Would an alignment after getting the tires help at all?
  30. Jul 13, 2024 at 8:37 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    An alignment just makes it steer correctly, has nothing to do with clearances.
