Readylift SST lift
Discussion in 'Suspension' started by Osojoe69, Feb 3, 2021.
  1. Feb 3, 2021 at 1:29 PM
    Osojoe69
    Osojoe69 [OP] New Member
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    Hey guys,I found this kit on Amazon..... and its about 150$ cheaper than what 4wheel parts wants for it.my question is should I upgrade my shocks while I'm at it.If so, what would be an economical way to go? and do they need to be adjustable? I only take the truck on fire roads and maybe some sand...I would love to have the funds for coil overs but this kit will work for now. I plan on adding a set of fuel mavericks d536 with a +20 offset and 295/60/20 down the road. Thank you all in advance...
  2. Feb 3, 2021 at 1:33 PM
    ptat
    ptat New Member
    If you're ok with Rough Country, then this kit is even cheaper.
  3. Feb 3, 2021 at 1:37 PM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    I saw that ty but there's a lot of negative comments about rough country kits...lol
    I also like the fact that their made here in America.
  4. Feb 3, 2021 at 1:45 PM
    TXTundra2722
    2015 Black Tundra
    Honestly blocks and spacers are all about the same..... not much..... actually there is absolutely zero performance gained in this and is specifically a "budget lift" only. Biggest thing here is make sure you get the spacers for your bumpstops. One of the biggest negatives that these sites never tell you is that your actually losing wheel travel from these types of lifts and your ride quality goes into the negative..... or worse than stock.
  5. Feb 3, 2021 at 1:47 PM
    EPecora
    EPecora New Member
    Evan
    Pennsylvania
    2013 MGM CrewMax Rock Warrior
    Hey man! I can't speak to any experience with this kit on a Tundra but I had a very similar setup on my 16 AC OR Taco. It did the job and was an easy install but the ride was horrible, albeit I didn't upgrade the shocks. I do think ReadyLift is nicer than Rough Country but you're still not getting much. When I picked up my Tundra a few months back, I installed this setup from Eibach https://eibach.com/us/1862/E80-82-067-01-22-TOYOTA-Tundra-pro-truck-lift-system. After experiencing the downgrade in ride from my ReadyLift, I knew that I didn't want to go the spacer lift route again if I didn't have to. I read up on this set up as well as similar ones with Billstein shocks. I'm very happy with the ride quality of this setup and for what you get, I think the price is very reasonable. You can adjust the fronts for 3" of lift but Eibach doesn't recommend it, I have it set for 2" on my truck. Best part is, my UCA's are still at a good angle. I'm running 285/70/r17 Ridge Grapplers that only rub on the skid plate at full lock. some spacers or offset wheels might get rid of the rub. I really recommend avoiding the spacer lift if your wallet can handle it. 5BCCE927-D179-48AE-B05E-7047836C2D31.jpg
    BravoDeltaRomeo and toyofan87 like this.
  6. Feb 3, 2021 at 1:56 PM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    Nice truck brother...Ill look into it...what else will I need..diff drop ...blocks...also Id like to have a true 3" lift up front and at least a 2" in back I like the rake
  7. Feb 3, 2021 at 2:00 PM
    EPecora
    EPecora New Member
    Evan
    Pennsylvania
    I didn't install anything else other than what came in the kit which was literally the front shocks and springs and the rear springs. You could probably install a small block in the rear to lift it further. If you're going to buy a spacer lift, make sure you get extended length shocks.
  8. Feb 3, 2021 at 2:07 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Joe (OP) you have a 2015 4WD Tundra, so it is safe to say you spent somewhere in the high $20k to mid $30k for your truck. Do you really want to install a cheap $200 suspension lift that will ride poorly on your nice and expensive Tundra? Read up on the different types of lifts (stickies in the suspension forum here). By the time you buy that cheap kit, and upgrade your shocks you will have probably spent more than doing a coil over lift
    As Evan stated, there are much better ways to get the lift that are really not too expensive. You will be happier with a lifted coil over vs a spacer. But as you probably know plenty of folks buy spacer lifts.....and then remove them later to move on to something that rides and handles better.
    But it is your truck, so do what you like. Quick read of pros and cons-https://www.unsealed4x4.com.au/the-pros-and-cons-of-spring-spacers/
    texasrho83 likes this.
  9. Feb 3, 2021 at 2:08 PM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    I dig that setup..if I do add a block in the rear..when you say extended length shocks...will the ones it comes with not work..and do you think I can get 3 inches up front..
  10. Feb 3, 2021 at 2:13 PM
    EPecora
    EPecora New Member
    Evan
    Pennsylvania
    Eibach gives you three options (1", 2" or 3") when you install the front coils and shocks. I can't remember exactly what the instructions said but it said to only use the 3" option to compensate for a heavy aftermarket bumper in the front. As for the rear, the shocks are good for 1" of lift.
  11. Feb 3, 2021 at 2:16 PM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    Hey Joe ..I'm listening ...and ty I know you guys speak from experience...and actually I got the truck for 20k cash I searched a lot and got exactly what I wanted from a wealthy guy very close to my house...it has 117,000 miles and is well kept...20210127_163750.jpg 20210127_163750.jpg 20210120_135751.jpg
  12. Feb 3, 2021 at 2:21 PM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    I'm still trying to figure out how to use this site...hence the double pic...I'm going to wait and see what my tax refund is...and I'll keep looking and listening to those that know...
  13. Feb 3, 2021 at 2:22 PM
    frichco228
    Nice truck! with that mileage it may be time for new shocks anyway so check out some of the lifted coil over options out there. Toytec makes several kits, then there are 5100s and 6112s you can check out too.
  14. Feb 3, 2021 at 2:27 PM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    I will definitely keep looking and reading thank you..I'm new to this and am not very knowledgeable about suspensions but budget permitting I'd like to do things right...
  15. Feb 3, 2021 at 9:24 PM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    Screenshot_20210203-213433_Chrome.jpg Screenshot_20210203-211939_Chrome.jpg What do you think guys...it beats a spacer lift right???
    Just asking...
  16. Feb 3, 2021 at 9:44 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    If you lift the front 3” you may need aftermarket UCAs to get a decent alignment. All trucks are different so there is no set rule but something to keep in mind if you want to lift the front that much.
  17. Feb 7, 2021 at 8:25 AM
    tripletundra
    tripletundra New Member
    Stuart Fl
    2021 Tundra Platinum
    K n N Cold air, 20x9 +1 Moto Metal, Winjet Tail lights.
    I just put a Readylift 4/2 SST kit on my 21 platinum and so far I like it. It’s only been a couple hundred miles but so far so good. CBAF3F45-F0D6-4D3E-880E-0973793E6DC2.jpg
    RoniusMaximus and marcelo73 like this.
  18. Feb 11, 2021 at 9:35 PM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    That looks tight my brother....I'm not sure what to do .lol....I have the 3/2 sst kit...but now I'm looking at the rc 3 1/2 coilovers....for a few bucks more..or maybe these...eibachs .Screenshot_20210203-211939_Chrome.jpg Screenshot_20210203-213433_Chrome.jpg
  19. Feb 12, 2021 at 3:46 AM
    tripletundra
    Stuart Fl
    I couldn’t make my mind up so I bought the 4/2 SST kit in Amazon for $685
    RoniusMaximus likes this.
  20. Feb 12, 2021 at 3:55 AM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Same. Amazon had the ready sst pro plus 2 (pretty much a 4/2 lift for TRD Pros) for $350 less than whay everyone else sold them for. I had my local 4wheel parts store price match. I had contemplated other lifts but ultimately I loved how complete the readylift kit was and it has a lifetime warranty.
  21. Feb 12, 2021 at 5:18 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I've had a 3" readylift kit on my truck since last year.
    Zero issues with it and rides like stock.
    I don't know where these "experts" are getting the "rides like crap" bullshit from.
    If you are not changing springs, spring rates or compressing them any differently than stock... how on earth will it change the ride ?
    You are simply changing (spacing) the attachment points. Think about it.
    Naysayers just like to feel better about dumping $4k into a completely different set of shocks and springs to lift the same 3" as the $200 spacers.
    Obviously a $4k setup will be better than stock if you spend most of the time offroad or running the Baja1000... but for 99% of the pavement princesses and work commuters(myself included), spacer lifts are just fine.
  22. Feb 12, 2021 at 7:20 AM
    TXTundra2722
    2015 Black Tundra
    :stirthepot:
    Science is hard to argue with. The more "mild" of the spacer, the less issue this will be. The stock Tundra suspension has a bit less than 9" of suspension travel available in its ball joints from the factory. This travel is limited by the stock strut to 8" over all. 4.0" up and 4.0" down on most models. When you lift your truck, you are raising up the front, lets say a standard 2.5". So now you have 6.5" up and 1.5" down. When the top spacer is added. You now have 3.5" up travel. as your shock is now your limiting factor, and 1.5" down travel as your ball joints are the limiting factor on the other side reducing over all travel from 8" down to 5.0". (Also.... don't yell at me if my numbers are slightly off.... the concept is still the same here.... I'm finishing a 20 hour shift).
    :pccoffee:
    Four things that this has caused. One, Your ball joints are your limiting factor on down travel and will wear them out or break them. Two, your bump stop is no longer the up travel limiting factor, your shock is and will cause your shock to fail on a large hit, or you did add the extension properly but still limits the range of motion. Three, the upper control arm can make contact with your strut or springs (can.....not 100% will) causing wear on the shock and control arms. Four, the over extended down travel can cause your CV axles to over extend and wear faster than expected or break while flexed off road. So to recap, first off..... this has nothing to do with "hating" on spacer lifts because those of us that saved our money a little longer and bought better suspension. If you keep the spacer lift mild....1-2 inches and are a pavement princess then you'll probably be OK, (even though a bad pothole or going too fast over a speed bump could be catastrophic for your shocks). Another reason spacer lifts get a bad rap is when you limit the range of motion in the suspension travel, it can make the ride feel more rough. Hope this clears up any "disinformation" that's being spread around out there. Also remember science..... that'll shut them up.... if not get ready for a "But my momma always told me that I was a winner in" 3....2....1....
    :boink:
    :poking:
    In all seriousness I don't care what you run on your truck, it's your choice clearly.... just figured we needed more of a scientific approach here.
    Vang530 and EPecora like this.
  23. Feb 13, 2021 at 7:50 PM
    EPecora
    EPecora New Member
    Evan
    Pennsylvania
    Please point to where someone claimed to be an expert. @TXTundra2722 spelled it right out. When you stick a spacer and extended block on your truck, it puts undue pressure on your stock components that were designed to work within a certain range. Go stick a 2-3" lift block on the back of your truck and look at what it does to the shock. It stretches it right out when sitting still. That block then limits downward travel and almost eliminates any extension from the shock. This directly effects ride quality. The spacer lift changes almost all your angles in the front, again changing how much travel which again directly effects ride quality. Not hating on spacer lifts, they serve a purpose and almost all truck guys run them at some point, its a right of passage. But if you think they do not affect anything I have ocean front property in Arizona to sell you.
    TXTundra2722 likes this.
  24. Feb 14, 2021 at 8:37 AM
    bullockdl
    bullockdl New Member
    2019 Limited 4wd
    Hoping to get some help from you guys. Im right at the finish line of installing a ReadyLift 3/2 and im putting the front diff drop spacers in. How in earth do you access the area to get a hold on the lock nuts to tighten things down?
  25. Feb 15, 2021 at 9:53 AM
    Osojoe69
    Jose
    Los Angeles CA
    2015 DC TSS 4x4
    20210215_091943.jpg 20210215_092033.jpg 20210215_092119.jpg Hey guys...ok so I think I want to go with the eibach setup up front...please look at these and tell me if it's just me but do these coilovers look alot beefier than the ones that aren't preassembled or the toytec ones...
  26. Mar 2, 2021 at 10:58 AM
    Tonkatoytaco
    Tonkatoytaco New Member
    Louie
    Maryland
    2017 Platinum XP MGM
    LRO 3/1 Leveling Kit, Dirty Deeds 10" exhaust, Bully Dog Programmer, AFE Super stock Intake with TB Spacer, Custom Rough Country Grill, Andres Devil Horns, Caliraised Fog lights, Morimoto XB Headlights, HRS taillight, Boost Auto tow mirrors, LED interior lights and Reg, light, Trail edition bed compartment, TRD rear sway bar, weathertech floor mats and window visor, Nitto Ridge grappler.
    How much is your ride quality effected by this lift?
    ackthresher likes this.
  27. Feb 4, 2022 at 1:23 PM
    Villstoy0415
    Villstoy0415 New Member
    978AD817-AD3A-4150-8DE4-7EEB1B502C74.jpg I just got the sst ready lift 4/2 installed on my 2021 TRD premium edition. Rides like stock. Cruising at 70-80 mph on the fwy, no issues.
    ackthresher and Dragracer_Art like this.
  28. Feb 4, 2022 at 1:35 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Yep... ive had my 3/3 on for 22,000 miles sofar.
    It still rides like a creampuff and have had ZERO issues.
  29. Feb 9, 2022 at 7:03 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    I've put about 1k miles on my 2021 with a 3/1 SST ReadyLift kit and it rides pretty close to stock IMO. That's going from bone stock with factory 18's and tires to a 3/1 RL with E load Toyo 295/60r20's. I don't do any hardcore offroading so I couldn't justify spending thousands on a setup. I'm happy with how everything turned out.
  30. Feb 28, 2022 at 5:06 PM
    dvs_one_76
    dvs_one_76 New Member
    Ken
    2017 Platinum
    GT87 what is the offset of you wheels. I'm pulling the trigger on the same Ready Lift kit you have, but the wheels i'm looking at are a +20. I think I'll be alright but always nice to see what others are experiencing.
    GT87 likes this.
