Rear alignment after leaves
Discussion in 'Suspension' started by Flockem, Apr 12, 2022.
  1. Apr 12, 2022 at 10:00 PM
    Flockem
    Flockem [OP] New Member
    Remington
    2016 Crewmax 4x4
    6112/5160 +CB shims SPC UCA and Diff Drop Toytec Shackles 35x12.50 BFG ATs on factory 20s Spidertrax 1.25s BMC Headlight Revolution SM LED Breather Mod Dents in the body due to trees...
    So I think I have an idea on the numbers I need for the front. The rear is my concern…
    Recently had icon suspension installed (front and rear) and it was driving pretty bad. Took it back to have it realigned and these are the numbers I got. At first the front numbers annoyed me but then I looked further and the rear numbers bugged me.
    I asked around and read some posts… still as confused. I’m sure I can get the front corrected but what about the rear?
    They replaced the leave packs and I’m curious how far off I am from stock, -.37 and .37 don’t seem right. Even though my toe is “0” is the -.37 and .37 something to stress over? And -.37 thrust angle?
    If the leaves need adjusting I’m assuming U bolts need to be replaced?
    35x12.5 on 17x8.5 0 offset
    Icon RXT leaves setting 2 (2”-3”)
    Icon tubular UCAs
