Rear Bilstein 4600 shock bushing/nut stack up?
Discussion in '1st Gen Tundras (2000-2006)' started by Jack McCarthy, May 16, 2023.
  1. May 16, 2023 at 5:41 PM
    Jack McCarthy
    Jack McCarthy [OP] Working remotely from the local pub
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Deja Vu…Unable to see the shaft threads to get the shock nut on the rear shock shaft with the proposed stack up below. Wondering what I’m doing wrong here. :confused:
    @w666 Didn’t you say you had issues with this or maybe I’m thinking of another member?
    Mr Badwrench likes this.
  2. May 16, 2023 at 5:50 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I had to force the shaft up to get the threads started. We might've taken a grinder to shorten one of the rubber bushings.
    Jack McCarthy[OP] likes this.
  3. May 16, 2023 at 5:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Bolt the bottom, jack up the axle until you see all the threads
    chugs likes this.
  4. May 16, 2023 at 5:54 PM
    Jack McCarthy
    Bill
    North of Boston
    Do I even have enough weight with an empty bed for that to happen?
  5. May 16, 2023 at 5:57 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    One of the washers should drop down to the bottom near the dust boot iirc.
  6. May 16, 2023 at 6:13 PM
    Jack McCarthy
    Bill
    North of Boston
    It does not unfortunately; there’s a small lip on each shock that prevents further travel of any washer they provided. I was thinking about emailing Bilstein about it.
  7. May 16, 2023 at 7:01 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Seems you have an estra wacher in there. I recall, bottom washer facing up, rubber bushing, truck mounting hole, another rubber bushing, then the top washer facing down.
    The two bushings on either side of the frame mount hole and the 2 washers on the outside of the bushings. snug down until bushing flattens almost to washer size.
  8. May 16, 2023 at 7:06 PM
    artsr2002
    'Yonder
  9. May 16, 2023 at 7:24 PM
    Jack McCarthy
    Bill
    North of Boston
    Interesting. The stock shock shows 3 washers originally.
  10. May 16, 2023 at 7:31 PM
    artsr2002
    'Yonder
    Interesting indeed. I always thought it was just like the sway bar links.
  11. May 16, 2023 at 8:20 PM
    Mr Badwrench
    Mr Badwrench New Member
    That's what I remember. I also remember it being a huge pain in the ass to tighten the stem nut.
  12. May 16, 2023 at 8:21 PM
    blenton
    blenton New Member
    This.
  13. May 16, 2023 at 8:27 PM
    artsr2002
    'Yonder
    Yep, I pulled up the 4600 Billies on Rockauto and it shows one of the washers to have a larger diameter hole. That one should go on the bottom and should drop as assassin said.
  14. May 16, 2023 at 9:17 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You dont need a middle washer maybe im wrong, but none of my shocks have ever had one
    edit- maybe im incorrect, i see a couple examples with the bushing above the mount sandwiched
  15. May 17, 2023 at 12:04 AM
    Jack McCarthy
    Bill
    North of Boston
    Oh, F me. Not only do I have a bitch of a time get off the shock, but these new ones are potentially defective. :annoyed:
  16. May 17, 2023 at 2:03 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    It should stack up just like the old one. There are two types of metal washers, the one with the nib goes in the middle. The white plastic washer on top of the blue sleeve (in your earlier photo) is only to help hold the blue sleeve in place during shipping/handling. It can be removed from your stackup to save ~ .030"...you'll need that extra room!
  17. May 17, 2023 at 3:40 AM
    Jack McCarthy
    Bill
    North of Boston
    Did the bottom washer on yours go to the bottom and touch the blue dust cover or did it hang on a small lip in the middle as mine shows with about an inch of separation?
  18. May 17, 2023 at 3:50 AM
    w666
    Maryland
    Should go all the way to the bottom literally touching the blue sleeve. You might have to open the hole dia. on the washer(s) to make it work.
  19. May 17, 2023 at 5:50 AM
    Jack McCarthy
    Bill
    North of Boston
    I figure I can get it to work with the smallest washer on the bottom. That surprisingly seems to go over the lip. Tightening the nut should bring it closer to the 2nd washer that only goes to that lip I’ve demonstrated.
    Worst case I have one rubber bushing crushed on top and the other at full height on the bottom.
  20. May 17, 2023 at 5:52 AM
    SouthWestGA
    SouthWestGA New Member
    Why not take a drill bit and widen out the washer a small bit just to have even surfaces for pressure
  21. May 17, 2023 at 11:00 AM
    Had to look up also for my 5100s and I saved this for posting at the forum. Looks like that's where @w666's image originated.
    Note one of the washers has a lip or flare around the hole, it's oriented as shown. Though I don't remember if mine had.
  22. May 17, 2023 at 2:16 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Hbjeff, Bmktw2 and Jack McCarthy[OP] like this.
  23. May 17, 2023 at 4:35 PM
    Jack McCarthy
    Bill
    North of Boston
    I figure this will most likely be my stack up (minus the plastic spacer):
  24. May 17, 2023 at 5:10 PM
    Middle washer is upside down. And I'm pretty sure bottom one closest to the shock body is supposed to be in the middle position.
    But I may be wrong.
  25. May 24, 2023 at 6:05 PM
    Jack McCarthy
    Bill
    North of Boston
    Pre-compression and memory retention to allow for it to fit when I’m ready to install. This is after only a 2 hour wait…
    bmf4069 likes this.
  26. May 25, 2023 at 3:16 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    If you go by the pic @shifty` posted above from Bilstein, the upper and lower washers appear to be identical, with the odd one being the middle/support washer. If that's the case then your middle and lower washers are reversed.
  27. May 25, 2023 at 4:45 AM
    Jack McCarthy
    Bill
    North of Boston
    The problem is that the smallest washer on the bottom is the only one with a center hole that will get to the bottom of the shaft and meet with the dust boot. The other two will catch on a lip 1/2 way down and not go further.
    His pic also shows 5100 shocks, not the 4600. What I have shown should be the correct orientation.
  28. May 25, 2023 at 5:07 AM
    Actually, that's not even from 5100. When I reached out to Bilstein it's what they told me to reference for my 5100s, and it applied to 'just about all our shocks' (not my words). But you're the one looking at the shock and the hardware, so you know better than anyone how things fit. We can only see the stack, but no lips etc.
  29. May 25, 2023 at 5:28 AM
    Jack McCarthy
    Bill
    North of Boston
    That’s as far as the larger washer will go (below). It’s difficult to see where the shaft is machined to be a few mils thicker underneath.
    shifty`[QUOTED] likes this.
  30. May 25, 2023 at 4:30 PM
    w666
    Maryland
    The pic I posted earlier was from the 4600's I just installed. If your washers don't stack right, it might just be a tolerance problem (they're just stamped parts). Make it look like the picture. Widen the holes a hair if you need to.
    PS. The upside down top washer seems odd, and made it much more hassle to wrench down the locknut...but I did it like that anyway
