Rear Bumper Bed Step
Discussion in '2.5 Gen Tundras (2014-2021)' started by TelemarkTumalo, Jan 12, 2025.
  1. Jan 12, 2025 at 1:47 PM
    TelemarkTumalo
    TelemarkTumalo [OP] New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    I find myself climbing into the bed of my truck fairly often and thinking of adding the OEM step.
    https://autoparts.toyota.com/products/product/bedstepr-pt39234210
    Definitely expensive and I suppose a Toyota tax for using OEM.
    From those who have tried this step, benefits and drawbacks.
    I know I am sure to get some catcalls from the strictly off road crowd, but my truck rarely sees anything more difficult than a fire road while camping or hunting.
  2. Jan 12, 2025 at 2:11 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    There are aftermarket ones for a whole lot less.
    Also, very doubtful Toyota is making that. They are just offering the product.
    Just search Bedstep for other buying options.
  3. Jan 12, 2025 at 2:26 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    Lots of complaints out there about the plastic step breaking on the aftermarket versions of the bed step which typically go for around $100 on ebay and Amazon. I installed the one Toyota offers on my Tacoma 10 years ago. No issues. Also installed the one Toyota offers on my 2020 Tundra a year ago and it was very challenging to install. You'll need to remove the plastic cap on the bumper and there's no room under the sub frame to get to the plastic tabs and release them. There are youtube videos where folks cut the existing metal sub frame bracket (with it in place) to mimic the replacement bracket. With this approach, no need remove the plastic cap and risk damaging it. If I were to do it all over again, I would have just cut the existing sub frame bracket.
    Here are the instructions. The bed step part number listed is different, however, the install procedure is the same. https://www.cc-parts.net/upload/documents/k8089.pdf
  4. Jan 12, 2025 at 2:45 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I bought the aftermarket one off of eBay and have had no issues at all. I weight 225 and have never had a problem. I cut the bracket as the previous post mentioned. I wouldn’t hesitate to buy again
  5. Jan 12, 2025 at 2:46 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I have the Amazon special. Been on since Nov. 20, 2024. Uses every time the tailgate open..
    Watch some youtube vid on how to install.. do not use the included bracket. Use the factory one, it is way more sturdy. The included bracket is very flimsy and weak. Bend easily.. there is a section of the factory bracket you need to trim out.. the rest is easy to go on..
    https://www.amazon.com/dp/B0D739K7LQ
    TelemarkTumalo[OP] and Trooper2 like this.
  6. Jan 12, 2025 at 9:56 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    I also purchased an aftermarket step on Amazon and have been very happy with it. I did remove my factory bumper support and put in the one that comes with the step. I wish I had watched a video or two skipping that process. It was not fun trying to install the one that came with the step. I may put the factory one back in come summer since I still have that one. I would have just cut it to match the one in the kit and saved myself a lot more work during install. The step otherwise does what it is supposed to do and with my Tundra lifted it was definitely worth it. Did not pay too much for it either considering how much some of the other ones I found were.
  7. Jan 17, 2025 at 7:24 PM
    hainesfive
    hainesfive New Member
    MD
    2020 Black TRD Sport Crewmax
    TRD Dual Exhaust Weathertech rear floor liner Black out badging Linex sprayed bed TRD PRO Wheels VLED Interior and exterior Drivers side grab handle Front drivers and passenger window tint Focal speaker upgrade with amp and 10" sub Retrax pro bed cover Falken tires
    Installed the Toyota one today and used the supplied bumper bracket. Took about 1 1/2 hours . Worst part is getting the plastic tabs loose without breaking them. Happy with the install and it's a game changer getting in the bed with fake knees.
  8. Feb 15, 2025 at 1:33 PM
    Sodamo
    Sodamo New Member
    David
    Big Island Hawaii
    2024 1784 Crewmax hybrid
    freerider8 likes this.
