Rear bumper cap removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigraz, May 16, 2019.
  1. May 16, 2019 at 7:17 PM
    bigraz
    bigraz [OP] New Member
    I have a 2018 and I want to remove just the right cover.Is there a easy way,or does the black plastic license plate housing with all wiring need to come off as well? if anyone has detailed instructions with pictures that would be appreciated!! Thanks!!
  2. May 16, 2019 at 7:21 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Not gonna lie, it's a pain.
  3. May 16, 2019 at 7:23 PM
    bigraz
    I was hoping it wouldn't be....
  4. May 16, 2019 at 8:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    Its not impossible, just a pain. There are a bunch of tabs that you have to pinch inorder to remove the big black plastic piece that runs the width of the bumper. You'll also need to pull the back side of the 7 pin trailer connector, which was a pain. You will need a bunch of screw drivers, so that once you pinch the clips and push them up you'll shove a screwdriver in so the clip doesn't go back in. You'll also want to use some ratcheting closed end wrenches to take some bolts off the top of the chrome pieces that are tight against the bottom of the tailgate.
    i believe there's a link to some install threads in "the ultimate oem parts thread"
  5. May 16, 2019 at 8:05 PM
    AZTundra
    Paul
    Phoenix, AZ
    I will concur....it's a hassle. Why are you needing to remove it?
  6. May 16, 2019 at 9:22 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    The top black piece comes off pretty easy with the help of some one else as like stated above lots of clips. I was at the bottom pushing clips and my wife was keeping pressure from the top so the clips wouldn’t go back in place
  7. May 17, 2019 at 8:31 AM
    bigraz
    I have a scuff/scratch in the right bumper,which i didn't do,and i can't stand looking at it!! Not sure if i want to replace it,have it painted or use the bumpershellz. The chrome doesn't bother me but its pricey to replace just a cap..
    AZTundra[QUOTED] likes this.
  8. May 17, 2019 at 9:13 AM
    AZTundra
    Paul
    Phoenix, AZ
    Bumpershellz might be the best/easiest solution then. I just ordered the fronts in white on Wednesday during the group buy. The group by is going on until next Wednesday (5/22/19) I believe if you want to jump in before it's too late. Group buy will get you 15% off. The fit and finish looks really good from the pictures others have posted up.
  9. May 17, 2019 at 9:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    You don't have to remove the whole plastic cover to do one side. Just make sure you have a racheting box end wrench of proper size. I believe it is a 12mm. Be careful not to break any of the tabs. I thought I had all mine released and ended up breaking one. Not the end of the world if you do especially if it is an inner one.
  10. May 17, 2019 at 12:09 PM
    bigraz
    Do you have to disconnect the license plate lights and the trailer harness??
  11. May 17, 2019 at 7:19 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Nope not if are just doing one side or one at a time. You can prop up the plastic cover enough to do one side. Like I said make sure you have a racheting box end wrench in 12mm. A racheting cresent would work too. Just not enough room for a rachet. You need to take the center bolts out not the ones towards the ends. You can deal with those once end cap is off.
