Rear bumper repair
Discussion in '2nd Gen Tundras (2007-2013)' started by Joea98, Oct 10, 2021.
  1. Oct 10, 2021 at 10:48 AM
    Joea98
    Joea98 [OP] New Member
    2012 double cab silver TRD Tundra
    Hey what's up yall. So I was finally able to join the Tundra family and I couldn't be any more happy.
    However yesterday I was backing up and unfortunately hit a cement column in my apartment complex. I dented the chrome right plate and lifted the plastic step cover a bit on the edge. Can I take this to a car shop for repairs vs having to replace the whole thing? Thanks 20211010_104937.jpg
  2. Oct 10, 2021 at 10:55 AM
    It's hard to tell from the picture but they might be able to reshape it. If not you might be able to find one for sale locally.
  3. Oct 10, 2021 at 11:08 AM
    Joea98
    Gotcha. The right chrome part is a bit sunken and the plastic step is a bit scratched and folded in.
  4. Oct 10, 2021 at 11:31 AM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    I think for the most part all of the old school bumper repair/re-chrome guys are gone. You might find one in select areas.... most body shops do not deal with bumper repairs, they like the easy route remove and replace
    Looks like time for a new bumper if you want it to look right
  5. Oct 10, 2021 at 11:31 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Probably. It’s hard to work dents out of bumpers. You might try a couple of big C clamps and a block of wood on each side. I’ve done that before.
    I just bought a replacement bumper for $185 shipped.
    Joea98[OP] likes this.
  6. Oct 10, 2021 at 1:43 PM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    Craigslist is always full of bumpers for sale. I’d look at that cuz otherwise it’ll cost lots more. I’m in Seattle and I look for deals from here to Portland to Spokane and in between. Even if you don’t find one immediately, they pop up. If you travel, expand your search.
  7. Oct 10, 2021 at 1:52 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
  8. Oct 10, 2021 at 2:22 PM
    Joea98
    Damn from where?
  9. Oct 10, 2021 at 2:25 PM
    JLS in WA
  10. Oct 10, 2021 at 8:43 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    It could be repaired fairly easy but would most likely have a super small spot that would off. These bumpers seem to thin and fairly easy to work with if you were to DIY an had some knowledge/experience in the area. But as for a option for a shop doing it would be best spent doing the cheaper replacement as body tech hours would come out the same or be more expensive.
  11. Oct 11, 2021 at 2:10 AM
    CMikeB
    CMikeB New Member
    I backed into a CONCRETE column with a Dodge years ago. I was able to cover the damage with a strip of peel & stick bumper trim. Yours might be too 'involved' though.:confused:
  12. Oct 11, 2021 at 11:17 AM
    Katblackdiesel
    Katblackdiesel New Member
    Kat
    Atlanta - Rome
    2007 Timberland Mica Tundra SR5
    I got rear ended by my buddy with a GMC 2500 the other day and my bumper suffered similar damage. Mine will require replacing, since it now interferes with the tailgate. Yours will probably be easier to just replace as well.
  13. Oct 11, 2021 at 2:57 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    Just replace the bumper shell (e-bay) and re-use the plastic trim cover...easy peasy and cheap.
  14. Jan 23, 2022 at 2:39 PM
    Ptlsmbttx
    Ptlsmbttx New Member
    Terry
    2017 Tundra
    I had a similar experience with a concrete column. It very slightly pushed the left side of the bumper out of original alignment. Has anyone fixed this? It looks like there might be a few bolts that can be loosened so that I could pull it back into alignment. Any help would be appreciated
  15. Jan 24, 2022 at 6:13 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    I see them regularly in my area for sale on Facebook marketplace and craigslist.
    Plenty on eBay. Car-part.com also has a lot of OEM used in great shape.
