Rear dashcam mount options
Discussion in '2.5 Gen Tundras (2014-2021)' started by pearlpower, May 12, 2021.
  1. May 12, 2021 at 4:51 AM
    pearlpower
    pearlpower [OP] New Member
    2014 CrewMax in Radiant Red
    Purchased a Thinkware U1000D and I am reviewing options on how to mount the rear camera. I do roll down my rear window often so mounting it on the glass it not an option. Curious what others have done. Might 3d print a bracket that slips above the headliner…..
  2. May 12, 2021 at 5:06 AM
    That would work. I have seen where some have used aluminum to make a bracket. I think your idea is better...less damage from rubbing. If you make one that works, let me know. I would be interested in buying one from you. :)
  3. May 12, 2021 at 6:53 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I used a small 90 deg piece of aluminum attached my rear camera to that then used 3M extreme double sided tape to affix it to the plastic trim above the center of the rear glass inside the cab. Gives me a nice wide angle of the rear, virtually eliminating blind spots and a view of what's in the bed.
  4. May 12, 2021 at 7:23 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
  5. May 12, 2021 at 8:15 AM
    pearlpower
    Could you please post a pic of your setup with this bracket? Thanks.
    g6t9ed[QUOTED] likes this.
  6. May 12, 2021 at 8:25 AM
    g6t9ed
    No problem. I'll have to do it later today as I'm at work (I know, I'm a bad employee right now). Also as a disclaimer, I previously just used the double sided tape that was on the camera originally and it had fallen. I now have Gorilla tape wrapped around the unit and bracket for about 3 weeks now and has since been good.
  7. May 12, 2021 at 8:49 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Ordered :spending:
    This should be a little nicer than my ghetto "screws in headliner" setup I have now.
  8. May 12, 2021 at 9:21 AM
    pearlpower
    Do you have the 1" or 2" version of the bracket?
  9. May 12, 2021 at 10:44 AM
    g6t9ed
    If memory serves me correct, I believe it's the 1" version. I'll definitely get you pics in a few hours. I also have it hooked up to the VIOFO A129 Pro Duo.
  10. May 12, 2021 at 11:35 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    This is great! I've been contemplating for weeks now how I would mount the rear camera with my sliding rear window. Looks like problem solved!
    GWill likes this.
  11. May 12, 2021 at 2:17 PM
    g6t9ed
    Here's the photos as requested. Looks like I have the 1" version so that means both should work. I do notice I need to adjust my headliner since it appears it's not properly tucked. Again, I'm using Gorilla tape in the meantime until I find a better solution. Hardly noticeable unless you're right on it. Hope these help!
    20210512_153434.jpg 20210512_153458.jpg 20210512_153339.jpg 20210512_153401.jpg
  12. May 12, 2021 at 2:44 PM
    pearlpower
    Thanks for posting. I might pickup the 1" version. the Thinkware rear is more a horizontal layout and it appears there is plenty of room for it to work.
    g6t9ed likes this.
  13. May 12, 2021 at 4:29 PM
    DSLKSL
    DSLKSL New Member
    Don
    I used a flat hard plastic sheet about 8x8 (old tucker mud flap) drilled two holes in it and removed the middle headrest marked the holes and stuck it through the plastic. Mounted the cam to that. I don't even see it because it's hidden by the headrest. I kept it about 1" away from the glass so I could roll the window down.
  14. May 12, 2021 at 5:35 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Mines outside above the third brake light.
    Lassie likes this.
  15. May 12, 2021 at 6:07 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    On the Dashcam Store site for this product, they have a tundra with the rear window down shown in use.
  16. May 12, 2021 at 6:09 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
  17. Sep 29, 2023 at 7:54 AM
    Hank
    Hank New Member
    I have the roll-down rear window. After reading about all the different options for mounting a rear-facing camera, I ended up with two strong earth magnets. I slid one up into the headliner, and mounted the other to the rear-facing camera with 3M tape. Then just stuck it to the headliner.
    TreeCat likes this.
  18. Nov 10, 2023 at 7:45 PM
    rebel1794
    rebel1794 New Member
    J
    2015 Tundra 1794 Sunset Bronze
    Side Steps
    That rear spoiler looks great!
  19. Nov 11, 2023 at 5:11 AM
    g6t9ed
    I appreciate it. I definitely wouldn't suggest getting one unless you color match it. The flat black on any of the colors just looks too out of place and makes it looks like it's just floating up there, lol. I know people on here are polarized on the spoiler, but with it blending so well, I haven't heard anyone disagree with my choice on getting it.
    Also, as a side note, I got rid of the Gorilla Tape and found a more permanent solution to make the rear dash cam more presentable.
    rebel1794[QUOTED] likes this.
  20. Nov 24, 2023 at 2:14 PM
    rebel1794
    J
    Side Steps
    Please do tell, I tried one of those metal mounting brackets but I couldn't get it to work with the 129 rear cord setup.
  21. Nov 27, 2023 at 2:57 PM
    g6t9ed
    So, I had to bend the bracket in order for it to align properly. If that doesn't make sense, let me know and I can try to do my best in taking better photos. But here's a few I took with bending the bracket and using super glue. Hasn't been an issue for the past 2 years.
  22. Nov 27, 2023 at 3:11 PM
    rebel1794
    J
    Side Steps
    So I think I see where I went wrong here, I got this https://www.thedashcamstore.com/custom-metal-mounting-bracket-for-adhesive-dashcam-lenses/ But you're using this one right? https://www.thedashcamstore.com/custom-folded-bracket-for-secondary-dashcam-lenses/ I went and got the smaller version thinking it could go under the headliner but your one actually mounts to the interior metal under the rubber molding. Looks like I gotta order the right version!
  23. Nov 27, 2023 at 3:43 PM
    g6t9ed
    You got it! Also keep in mind that you don't have to bend the bracket like I did. I just wanted to based on how it fit with the Viofo rear cam.
  24. Feb 6, 2024 at 1:45 PM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Just got one of the brackets and its not that great. It looks like someone painted it with the cheapest can of paint, which doesn't to stick to the metal and comes off. Mounting the cam to the bracket does not seem to hold.. Also, zero instructions on the site. The mount does not fit no matter how you try to mount it.. Does anyone know how to mount it, now matter what i try it either sticks out too far for the window not to close, or its really loose and is moving all over the place. PXL_20240206_205656155.jpg PXL_20240206_210557891.jpg PXL_20240206_212137348.jpg PXL_20240206_212222355.jpg PXL_20240206_212400180.jpg PXL_20240206_212629461.jpg
  25. Feb 7, 2024 at 12:10 AM
    MrJimmyPenguin
    MrJimmyPenguin Penguined
    Jimmy
    2021 Black Crewmax Toyota Tundra TRD Off Road Premium 4x4
    I also use the u1000, and just put a binder clip for the rear, works great and super cheap.
    Norfolk757 likes this.
  26. Feb 7, 2024 at 8:40 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    I got one and I love it
  27. May 16, 2024 at 10:47 PM
    JustDrivinAround
    JustDrivinAround New Member
    24 CrewMax
    If someone has a minute, could you show me how to remove the back window weatherstripping? The ones around the doors are pretty easy to remove, but the back one didn't budge. I'm a bit of a chicken to yank on it. I ordered the Dashcam Store custom folded bracket mentioned above.
    Thanks.
