Rear Differential Fluid oil change??
Discussion in 'General Tundra Discussion' started by CamaroSsToTundra, May 6, 2019.
  1. May 6, 2019 at 3:24 PM
    CamaroSsToTundra
    CamaroSsToTundra [OP] New Member
    Ohio
    2018 Tundra
    I have 2018 Tundra Sr5 4x4. And my current mileage is 13,000 miles. When should I change my rear differential fluid? In owners manual I think it says change at 15k. When did you change your’s??
  2. May 6, 2019 at 3:25 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    15k??? That seems weird
    Can’t remember for sure but it’s like 30k for towing and 60k otherwise.
    CamaroSsToTundra[OP] likes this.
  3. May 6, 2019 at 3:48 PM
    trdprobped17
    trdprobped17 New Member
    15k-20k miles on my 2010 cm 4x4. On my 17 CM 4x4, I plan to change them every 20k or every other year. I’m running 4.88 nitro gears on front and back, so I had to change it twice in the first year. I think that driving conditions, such as, terrain, usage, mileage per year, etc., will ultimately determine how often the oil needs to be replaced.
  4. May 6, 2019 at 4:02 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    Oh ok I didn’t change any gear ratio. Everything is stock.
    trdprobped17[QUOTED] likes this.
  5. May 6, 2019 at 4:14 PM
    koditten
    Kirk
    Midland of the Mitten
    I love these types of questions. It tells me you want to keep the truck for a long time.
    I just got done changing a rear wheel bearing last fall. To do that you need to pull the axle. The diff oil that was coating the axle looked as good as new oil. I decided to not touch the differential fluid.
    I just got back from a 1200 mile trip. I may change it when I get to 200,000 miles in a couple of years...or not.
    Unless you drive the truck thru water submerging the axles, there is not much to worry about.
  6. May 6, 2019 at 4:54 PM
    trdprobped17
    With stock I would still change it out every 20k-30k mile, and or every other year depending on your driving situation. As a rule of thumb, I try not to have any of my fluids in my vehicles go for more than every other year. But, I do take my 17 Pro off-road and I tow with it as well. So, I do change it much more often than usual because I plan on keeping the truck for, as long as, I can.
  7. May 6, 2019 at 4:55 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  8. May 6, 2019 at 5:22 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I've got Red Line oil sitting in the garage. I'm at 47,500 miles right now. And will do it between 50k and 60k. Rear and front diff. Transfer case too.
    You didn't ask but I'll be doing the transmission fluid/oil then too.
  9. May 6, 2019 at 6:07 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Did mine at 39k. First change. Looked cleaner than Tacoma's at 30. Most trucks you might change at 100 and you have pull diff cover to do it. Toyotas are only ones I have owned with drain plugs.
  10. May 6, 2019 at 6:11 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    So I might be good for another 7-8k. I am at 13,000 miles right now. How much it usually cost from dealership?
  11. May 6, 2019 at 8:20 PM
    teedubbya
    Austin TX
    Not sure but it’s honestly super easy to do. Drain, replace drain plug washer, and fill.
    Heff likes this.
  12. May 6, 2019 at 8:34 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    Yeah I saw video online. I will give dealers to take care of it until 25k then I will start doing experiments lol
