Rear differential oil 2004 two wheel drive
Discussion in '1st Gen Tundras (2000-2006)' started by George 7250, Dec 16, 2022.
  1. Dec 16, 2022 at 12:53 PM
    George 7250
    George 7250 [OP] New Member
    Factory specs on rear gear differential oil for a two wheel drive Tundra crew cab V8; 2004 model unlimited.
  2. Dec 16, 2022 at 12:59 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  3. Dec 16, 2022 at 1:04 PM
    George 7250
  4. Dec 16, 2022 at 1:20 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Maybe the website, maybe theres a sticker on the axle. Neither is a guarantee. But if you floorboard it from a stop and one wheel spins, its open. If both wheels spin, its lsd. You'll need about 4 qts of 75w90, and if its lsd it'll take less, and theres an additive you add in (or but lsd oul with the additive pre-mixed).
    Drive around to warm the axle up before draining, and fill until it starts to come back out of the fill hole.
    FrenchToasty likes this.
  5. Dec 16, 2022 at 1:29 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
  6. Dec 16, 2022 at 6:11 PM
    LSD usually would have a sticker indicating it's LSD on the back of the pumpkin. See here: https://www.tundras.com/threads/hel...lip-differential-06-tundra.29557/#post-729734
    But you should sign up for the Toyota Owners site linked there. And plug in your VIN, assign it to yourself. You can see there what options it came from the factory/port with, including LSD.
    Also, if you haven't read it yet, check this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Check that timing belt!
    Mr.bee likes this.
  7. Dec 16, 2022 at 6:15 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Still worthwhile to manually check for limited slip. It was not uncommon (and not terribly expensive) to add the Kazuma TRD lsd unit to an open diff.
  8. Dec 16, 2022 at 6:16 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Can you see lsd vs spidergears from the fill hole? Havent opened mine since like 2012.
  9. Dec 16, 2022 at 8:06 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm gonna have to ask for a source on this one. I'm pretty sure they are all 75w90 but feel free to prove me wrong.
  10. Dec 16, 2022 at 8:16 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    owners manual
    Toyota revised in 2003
  11. Dec 16, 2022 at 8:26 PM
    NickB_01TRD
    Nick
    KY
    Interesting.
  12. Dec 17, 2022 at 7:46 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Is there a general rule here? LSD for 4WD.
  13. Dec 17, 2022 at 7:48 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    no general rule, plenty of 4x4’s sold with open diff
  14. Dec 17, 2022 at 8:44 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    My 06 2WD has a LSD
  15. Dec 17, 2022 at 11:31 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    That isn’t always a guarantee, an open diff can spin both if traction is equal. That being said, Open diffs suck!
    Mr.bee[QUOTED] likes this.
