Rear Driveshaft Parts? Help!
Discussion in '2nd Gen Tundras (2007-2013)' started by DTaylor, Nov 14, 2019.
  1. Nov 14, 2019 at 9:00 PM
    DTaylor
    DTaylor [OP] New Member
    David
    2007 Dbl Cab
    BDS Lift Kit
    Shop says I need a new driveshaft.... looks like I could replace the carrier bearing and the yolk in the center (the one that needs to be removed in order to replace the carrier bearing). Problem is I cannot seem to find anywhere that sells this yolk? What am I missing?
  2. Nov 14, 2019 at 9:18 PM
    2manytoys
    2manytoys New Member
    Lupe
    Carlsbad, New Mexico
    2017 black tundra crewmax
    Fab fours premium bumpers frt & rr, retracing bed cover, 5% window tint cept frt which is 60%, has lift from dealer maybe 3 inch
    Maybe if you looked for yoke instead of yolk.
    BobCosby likes this.
  3. Nov 14, 2019 at 9:31 PM
    DTaylor
    David
    2007 Dbl Cab
    BDS Lift Kit
    Thanks for the help with my spelling.... you wouldn’t happen to have anything helpful or intelligent to say?
  4. Nov 14, 2019 at 9:55 PM
    SouthWestGA
    SouthWestGA New Member
    Spicer driveline components make a majority of Toyota stuff
    Perhaps calling them can help if you can get the Toyota parts counter to give you part numbers they can cross reference
  5. Nov 14, 2019 at 10:09 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The Spicer (Dana) part number for that yoke should be 5006150 if it’s a 5.7L, but availability maybe another story. Try some driveshaft shops in your area.
  6. Nov 14, 2019 at 11:16 PM
    DTaylor
    David
    2007 Dbl Cab
    BDS Lift Kit
    Hmmm... Yup... discontinued with no replacement. Maybe this is why the shop said I need to replace the whole driveshaft?
  7. Nov 15, 2019 at 2:26 PM
    Dr_Al
    Dr_Al New Member
    Al
    Call some junk yards. Not sure where you are located but finding a used driveshaft shouldn't be too hard. My guess $300 to $400.
  8. Nov 21, 2019 at 6:48 PM
    DTaylor
    David
    2007 Dbl Cab
    BDS Lift Kit
    Before I dive into this repair... will it be possible to drive in 4wheel after removing the rear driveshaft, or will I leak fluid from the center diff?
  9. Nov 21, 2019 at 7:40 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Yes you can do that.
    Are you the real David Taylor tho?
