Rear lift blocks?
Discussion in 'Suspension' started by sigmundsauer, May 31, 2019.
  1. May 31, 2019 at 1:10 PM
    sigmundsauer
    sigmundsauer [OP] New Member
    So I know there can be issues with axle wrap but are there any other downsides to a modest rear block lift, like ToyTec's 1.5 aluminum block? Will aluminum hold up, is it durable?
    Thanks,
  2. May 31, 2019 at 1:16 PM
    Midway
    Midway New Member
    I had aluminum 1.5" blocks on my 2nd Gen, held up just fine. But, do to experiencing axle wrap, I swapped out with shackles. Zero issues after that.
    Black Wolf and 15whtrd like this.
  3. May 31, 2019 at 2:10 PM
    sigmundsauer
    Thanks for the feedback, Midway.
    Midway likes this.
  4. May 31, 2019 at 2:22 PM
    Could you please explain axle wrap? I have 2 inch blocks currently. Thanks.
  5. May 31, 2019 at 2:36 PM
    sigmundsauer
    My understanding is that axle wrap is a result of increasing the distance between the springs and the axle thru the block lift. It makes it easier for your vehicle to over torque the axle against the compliance of the leaf springs because of the increased leverage between the springs and axle. I've read that this is typically not an issue with smaller blocks (less than 2") and is exacerbated by more powerful engines and positive traction situations where the tires easily grab or lock up with the ground. If experienced, it can increase stress on the block itself and/or u-joints....theoretically. I've also read that it's not as big of a problem as some people make it out to be. Just something to be mindful of.
    MRQZTNDR93 and Boerseun like this.
  6. May 31, 2019 at 2:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Axle wrap is the axle wanting to twist in place when you jam the gas. We have a ton of torque and only a couple main leaf springs. So with a lift block you are giving extra leverage to that twisting motion. It will distort the leaves a little under hard acceleration.
    Imagine the bar resting on a weight rack. Twist it with just your finger tips and it is tougher. Grab it with your arm extended and it twists very easily
    If you drive soft it likely won’t be an issue. Lift blocks over an inch aren’t a good long term idea though
    Midway likes this.
  7. May 31, 2019 at 4:55 PM
    Are Coachbuilder +3 (1.75 lift) shackles the only ones that will get me closest to the 2 inch lift that I have in the rear now? My ultimate goal at some point is to replace my ReadyLift 3/2 with Toytec Boss coilovers set at 3" and I want to keep my ride height where it is now. Its a 2013 2wd with the 4.6.
  8. May 31, 2019 at 5:04 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The CB shackles will tighten up your suspension a little.
    You could run +2 and a 1 inch block if you want to keep the same height, or run the +3 and only drop a half inch or so in the back
  9. May 31, 2019 at 5:09 PM
    I probably wouldnt even notice a half inch. The Toytec and the +3s would keep me pretty level? It sounds like I would be better off with no block at all? I need to pull my Bushwackers off and find level ground so I can see where i measure currently.
  10. May 31, 2019 at 5:22 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wouldn’t stress out about if it measures perfect level. Half inch is gonna be pretty small difference
  11. May 31, 2019 at 5:25 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Thicker leaf packs will resist axle wrap
    15Yota likes this.
  12. May 31, 2019 at 5:36 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Big J and Tundra234 like this.
  13. Jun 1, 2019 at 10:35 AM
    buffaluphagus
    buffaluphagus —————————————
  14. Jun 1, 2019 at 1:48 PM
    xtyfighterx
    Ty
    North Idaho
    Nope super heavy duty and fit perfect gave me exactly 2” of lift
    Big J likes this.
  15. Jun 1, 2019 at 2:09 PM
    buffaluphagus
    Hows the ride? I have 1” blocks that i think make bed bounce, unless its in my head and was always like that.
  16. Jun 1, 2019 at 2:12 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Small blocks like 1" or 1.5" are common with spacer leveling kits and are perfectly fine. The amount of torque added over 1" is very small and typically not noticable. I would not run 6" blocks, but likewise 6" shackles are not a thing either - at that point you would look at a different spring setup.
    So, shackles might be better in theory, but small blocks are okay.
    buffaluphagus likes this.
  17. Jun 1, 2019 at 2:13 PM
    Boerseun
    Ferdie
    Sarasota Florida
    I don't think there is any logical explanation why a 1" block would cause bed bounce.
  18. Jun 1, 2019 at 2:30 PM
    buffaluphagus
    Well there is a freeway near my place that basically has what seems like slits in it for a few miles, causes a less than desirable ride. Rear end bouncing up and down. Not sure if the blocks make it worse or if it makes no diff.
  19. Jun 1, 2019 at 2:47 PM
    Boerseun
    Ferdie
    Sarasota Florida
    I just don't see how the block can cause that. I am engineer so I look at things analyticaly instead of just opinion, and looking at the suspension system with and without blocks there is just no reason why the blocks would make any difference.
  20. Jun 1, 2019 at 3:45 PM
    xtyfighterx
    Ty
    North Idaho
    I had 1” block before my shackles and it’s noght and day difference feels like I’m On a cloud now
  21. Jun 1, 2019 at 3:59 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Those heavy duty sha shackles are what I plan for. Unless I go nuts one full blown bracket lift :thumbsup:
    xtyfighterx likes this.
  22. Jun 1, 2019 at 4:01 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
  23. Jun 1, 2019 at 4:30 PM
    xtyfighterx
    Ty
    North Idaho
    I didn’t plan on doing bushing but I found my shackle bolt was basically rust welded to the stock bushing so I had to torch and pound them out and I replaced with poly. I got the passenger side out with a ball joint press but the driver side wasn’t having it
  24. Jun 1, 2019 at 4:33 PM
    xtyfighterx
    Ty
    North Idaho
    Big J likes this.
  25. Jun 1, 2019 at 4:34 PM
    xtyfighterx
    Ty
    North Idaho
    You will probably wanna do shackles anyway with a bracket lift. Reduce the block size or give it some rake.
    Big J[QUOTED] likes this.
  26. Jun 1, 2019 at 5:17 PM
    buffaluphagus
    Did they come with hardware?
  27. Jun 1, 2019 at 7:32 PM
    xtyfighterx
    Ty
    North Idaho
    No hardware I just went to the local hardware store and got new stuff wasn’t much maybe $10?
  28. Jun 2, 2019 at 6:36 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Shackles!!!!!!
  29. Jun 2, 2019 at 6:44 AM
    Did you end up installing your Toytecs? Too many threads to keep up with lol.
  30. Jun 2, 2019 at 6:54 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    @Tundra234 I was able to swap out the Eibach coilovers for the BOSS coilovers and installed everything last week. It was a long day but well worth it. It turned out great!!!
    GiantsFanDan likes this.
