Rear running light issues
Discussion in 'Lighting' started by _big_rig2, Jul 29, 2020.
  1. Jul 29, 2020 at 11:07 AM
    _big_rig2
    _big_rig2 [OP] New Member
    2016 Tundra Crewmax 4or Silver Sky Metallic
    4" lift, rock lights, LED headlights, 40" light bar, Winjet Renegade Taillights, Nitto Ridge Grapplers, etc, etc
    Good afternoon everyone,
    I have a strange dilemma that I haven't quite figured out. Apparently I have no rear running lights at night. My brake lights, turn signals and reverse lights all operate when engaged. But when I'm driving at night, I have no rear lights shining. I changed the fuse under the steering wheel and it immediately blew again. Please help!!!
  2. Jul 29, 2020 at 11:37 AM
    Sounds like there is a break in the wire or something is shorting out in the running light bulb. Pull the rear lights and start from there. Most likely it is a bad connection around the bulb area that is touching metal and popping the fuse.
    Good luck, let us know what you find.
  3. Jul 29, 2020 at 11:38 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    If it blew immediately, there is a short somewhere. Frayed or pinched wire. I would remove the rear tail lamps and inspect the bulb, and wire individually. making sure nothing is pinched or any corrosion caused by rain water.
