Rear shackle leveling / lowering kit?
Discussion in '1st Gen Tundras (2000-2006)' started by keenxxx, Oct 13, 2019.
  1. Oct 13, 2019 at 8:13 PM
    keenxxx
    keenxxx [OP] New Member
    I have a 2005 Double cab 2wd and want to level the truck by lowering the rear 2". I bought a rear shackle kit off E-bay and either I got the wrong kit or its poorly made. Stock shackle width is 74 / 73mm, E-bay kit was 70 / 70mm width too wide and too narrow. Can anyone recommend a set of rear shackles? Thanks.
    Rex Kramer likes this.
  2. Oct 13, 2019 at 8:44 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I haven't seen a shackle that will drop you that far. Total Chaos makes one that will drop the rear 3/4"
  3. Oct 13, 2019 at 9:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    A 2 inch lowering shackle is probably a bad idea. It will really wreck your pinion angle.
    Tundyfundy and OR18TRD like this.
  4. Oct 13, 2019 at 10:18 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    While you do have a point, they do make things like axle shims to correct pinion angle.
    OR18TRD likes this.
  5. Oct 14, 2019 at 12:58 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Maybe look into a flip kit. That puts the axle over the leaf springs instead of under. However that'll likely net you 5 inches of drop in the rear
  6. Oct 14, 2019 at 4:42 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    bmf4069 and Darkness like this.
