Rear Shackle-Other reasons to install besides lift?
Discussion in 'Suspension' started by fireman_pete, Dec 22, 2021.
  1. Dec 22, 2021 at 1:18 PM
    fireman_pete
    fireman_pete [OP] New Member
    Pete
    2021 SR5 Trail Edition
    I am getting my new suspension installed on the 27th. Eibach 2.0 set at 2.5" on the front, and Bilstein 5160's on the rear, plus the TRD rear sway bar.
    I also purchased a CB 3+ shackle, but having second thoughts on the install.
    I do not plan to install any large tires than 33". Is there any benefit (other than lift) to install the new rear shackles?
    This is on a 2021 SR5 4x4.
    Thanks!
    Pete
  2. Dec 22, 2021 at 1:21 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    the shackles provide a smoother ride compared to stock and help to reduce any bed squirreliness as well. What are your second thoughts? I have a set of +3s i need to put on still but I am going to use the stock rubber bushings instead of the poly since I have a 21 and the stock ones would provide a smoother ride compared to the polys.
  3. Dec 22, 2021 at 1:27 PM
    fireman_pete
    Pete
    Second thoughts are two or three fold. I prefer the look of a level truck, and if I install the shackle, it wont be level. Second, since I have no plans of larger tires, and I just better keeping with the stock shackle. Third, I tow about 6500# a few times a month, and not sure the impact (if any) a shackle would have on towing.
  4. Dec 22, 2021 at 1:36 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Since you tow, look into RAS for the rear vs shackles. Minimal lift with it, .25 to 1 inch, will stop sag when towing.
    2mchfun likes this.
  5. Dec 22, 2021 at 1:55 PM
    fireman_pete
    Pete
    Funny, I was justy looking at the RAS earlier this morning, and that is one of the reasons I was having second thoughts on installing the shackle.
  6. Dec 22, 2021 at 1:58 PM
    The factory shackle bushings are splined so they limit movement. I have Toytec shackles with poly bushings. You are not going to notice a ride difference between the rubber and poly.
    15whtrd likes this.
  7. Dec 22, 2021 at 2:03 PM
    frichco228
    Yes, well tundra leafs are fairly soft, so there is some squat once you get 300+lbs in the bed or tongue weight. RAS will really help, all but eliminate squat without needing to move to custom leaf springs or add a leaf which may ride harder and sit higher than you want. Great alternative for a leveled truck, so when you do tow and you are already level, you won't be looking like one of those Carolina squat trucks@
  8. Dec 22, 2021 at 2:05 PM
    MadMaxCanon
    The shackle would not have impact on towing other than taking away excessive sag, since you would be higher. If you do the +3's though, do bump stops, I got durobumps.
    An alternative since you tow is RAS like mentioned, or airbags.
  9. Dec 22, 2021 at 2:39 PM
    fireman_pete
    Pete
    I just ordered the RAS, and will not be installing the CB 3+ shackles. We will see how that works, and make adjustments if needed.
    Thanks all!
    2mchfun likes this.
  10. Dec 22, 2021 at 5:54 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Coachbuilders smooth out the ride in the tail very noticeably.
    The +1s are the way to go with a leveling kit and you want minimal rake.
    I have Falcons and Coachbuilder +1s and the stance and ride are great.
  11. Dec 22, 2021 at 5:59 PM
    2mchfun
    Ironman greasable shackles and bushings here. RAS HD kit too. Anyway, the greasable shackles improve the ride without adding lift. Just another option.
    AggiePhil likes this.
  12. Dec 22, 2021 at 6:17 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I ordered the 1 inch CB shackles a week ago. My Tundra has a small spacer up front that gave me about an inch of lift. I want my factory rake back because now it always looks like it’s sagging with weight in the bed or when my trailer is attached. I personally don’t think the Tundra looks good leveled or near leveled (my case).
    I hope those poly bushings don’t make for a rougher ride…. I would not be happy…
  13. Dec 22, 2021 at 6:39 PM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    What was the front lift you had? Any pics of your current set up? I just ordered +1 shackles and the shims for up front to basically give it 1” all around and the smooth ride
  14. Dec 22, 2021 at 6:54 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Below photos is with about 400 pounds in the bed.
    Below is with an empty bed and a full tank of gas. 18E129A9-2D88-4BCF-A1D8-832CFB237617.jpg
    I have not much weight on the trailer but no idea to amount.
    I have the Coach Builder 1 front spacers. They provided about 3/4 inch of lift and they (Coach Builder) provides excellent alignment specs. It really rides great and wanders less than the factory alignment. I am in the minority but I like the factory ride in addition to wanting a little height.
  15. Dec 23, 2021 at 4:19 AM
    Eborseti22
    Evan
    Truck looks great! Seems like we both are in the minority! That's my same plan though, CB 1 Shims out front, CB +1 Shackles in the back, maintain factory ride. Just reinforced me going that route! Thanks for the photos!
    Oey12[QUOTED] likes this.
  16. Dec 23, 2021 at 4:42 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    Thanks! It definitely it the route less taken but I have been extremely happy. I wish I got the shackles from the onset though…no biggie. I have used 5100’s and Eibach leveling shocks on many of my past Toyota trucks, four to be exact. And with that said small spacers and such are just as good at accomplishing the goal of a small lift without getting rid of perfectly good suspension components and affecting ride quality.
  17. Dec 23, 2021 at 4:58 AM
    Eborseti22
    Evan
    I'm with ya - Had a 3" OME on my 2011 Tacoma that I traded in to get this guy. Awesome for offroading, but let's be honest, I only did it a half dozen times. Made for a rough daily driver, but looked great. Still miss it, but on to a new chapter!
    2011 Tacoma the day I said goodbye
    Current 2020 Tundra
  18. Dec 23, 2021 at 5:26 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    I had a 2003 Taco with OME coils and Bilstein 5100’s…I chalk that up to being a very expensive mistake. 0904B8DD-4503-4177-83A4-CC17DDB67D09.jpgHere’s my 2012 pre Bilstein lift.
    I miss all my Tacoma's, all three of them were rock solid. But the Tundra is better in many more ways. Your Tundra going to look great with a little height.
  19. Dec 23, 2021 at 5:38 AM
    Eborseti22
    Evan
    Good looking Tacoma! I agree, lot more capabilities now with a family with the Tundra. At some point in the future when it is completed, I'll report back with some photos!
  20. Apr 20, 2024 at 7:08 AM
    gsprenger
    gsprenger New Member
    Garrett
    2014 tundra SR5
    Hey guys,
    I recently received a full OME tundra lift kit without rear shackles. It is the budget OME kit with dakars in the rear. I did not order shackles simply to save money. But I’m worried about installing the dakars with the OEM shackles. If I have to use heat to remove them will it destroy the stock bushings? I just don’t want to get partway through the rear suspension and realize I needed the shackles. Let me know what you think! Btw still trying to save money!
