Rear Shock Bushing Question
Discussion in '2nd Gen Tundras (2007-2013)' started by Borgunit, Jun 6, 2022.
  1. Jun 6, 2022 at 10:25 AM
    Borgunit
    Borgunit [OP] New Member
    JR
    Ohio
    2013 Black Rock Warrior
    I am replacing the rear shock bushings. The Toyota website shows "off road" and "non off road " versions available. I do not really do any off roading so should I assume that I should get the "non off road" versions? Thanks.
  2. Jun 6, 2022 at 10:54 AM
    Think it’s referring to which suspension package came on your truck. TRD Off-Road is like a Z71 package for Toyotas. Different shocks and some stickers. If your rock warrior came with the off road package (I would think it would?) then you would order the off road version. If your on factory shocks and the bushing is wore out, maybe the shock is wore out too…….
  3. Jun 6, 2022 at 11:10 AM
    Borgunit
    JR
    Ohio
    I am replacing the shocks and I could see the old bushings had some hairline cracks. I am replacing them because of that. I was asking since I would prefer a smooth ride as opposed to off roading capabilities.
  4. Jun 6, 2022 at 11:12 AM
    I got ya, but the bushings go with the shocks I believe. Not a preference thing. New shocks should come with new bushings.
  5. Jun 6, 2022 at 4:31 PM
    72GTS
    72GTS New Member
    Ontario, Canada
    2021 MGM Tundra DC TRD Sport Premium
    My Bilsteins did not come with new bushings. I had to buy them separately, but I don't recall any difference between TRD and non TRD for bushings. I bought Gabriel bushing, part # 143340.
  6. Jun 6, 2022 at 6:45 PM
    My 5100’s came with new upper and lower bushings. Fronts and rears.
  7. Jun 7, 2022 at 6:00 AM
    72GTS
    72GTS New Member
    Ontario, Canada
    I used Bilstein 4600 series shocks and struts. The 4600 rear shocks did not come with new upper bushings.
  8. Jun 14, 2022 at 6:56 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Bought the attached when I changed out my front and rear shocks.
