Rear Sway Bar or Not? Offroading
Discussion in '2.5 Gen Tundras (2014-2021)' started by MOQS, Jun 7, 2018.
  1. Jun 7, 2018 at 9:12 AM
    MOQS
    MOQS [OP] New Member
    Gary
    Missouri
    2017 SR5 4WD Crew Max
    3/1 leveling kit, DV8 front bumper, Smitty Built X20 winch, Spyder head lights, Eagle Eye tail lights, American Racing ATX 18" rims, General Grabber x3 33x12.5x18 tires. TRD Pro front grille. Rigid Industries 's R2-46 Driving Pair, BAK Revolver X2 Tonneau Cover, GoRhino RB10 Running Boards, Rugged Ridge 3.5" Fog Lights, Rear painted bumper(Black), Tinted windows, Weather Tech window deflectors
    Need opinions on if I should install a rear sway bar if I will be using my truck for occasional off road use in the mountains?
  2. Jun 7, 2018 at 9:18 AM
    I've heard no, ya dont need, and I've heard of taking off the front one as well for off-roading
    Bprose and MOQS[OP] like this.
  3. Jun 7, 2018 at 9:37 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    The entire premise of a swaybar is to prevent articulation, by tying the wheels to each other and the frame. If you are just hitting dirt roads, but want better pavement manners, then it would suit you. If you want comfort and capability offroad, then negatory. A swaybar will limit offroad performance, unless you run something like a currir antirock, which is design specifically for large articulation offroad. An antirock will not give you good road manners though, its an offroad swaybar.
    MOQS[OP] and Sunnier like this.
  4. Jun 7, 2018 at 9:40 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I’ve had one, it was great when I was a mall crawler. Once I put some king shocks on both sway bars came off, mucho better!
    MOQS[OP] likes this.
  5. Jun 7, 2018 at 9:40 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    For easy and moderate off road, having a sway bar is a non-issue. Sway bar helps a lot when turning corners, reduces body roll (lean), especially for lifted trucks.
  6. Jun 7, 2018 at 10:10 AM
    Forget the TRD rear sway bar...The Helwig rear sway bar is adjustable and you can get quick disconnects to use when off roading!
  7. Jun 7, 2018 at 10:28 AM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    Depends on your definition of offroading, but it isn't hard to disconnect if you find the lack of articulation limiting you.
    trayday, Prostar 190 and MOQS[OP] like this.
  8. Jun 7, 2018 at 11:14 AM
    15whtrd
    15whtrd Mr. Blonde
    Wish I would’ve known that before I ever bought the TRD. Quick disconnects would be awesome.
    But I just flexed my truck yesterday on the way home from work. Our yard at work has dirt piles along the exit road. Seemed like it flexed pretty good even with the sway bar on. I’m sure he could do better without but it wasn’t a brick either.
    7A13BEFB-F2AF-493E-83AD-69B3BEE69DEF.jpg 3C09F3ED-BB54-49D3-B9AB-C51802CDCEB8.jpg
    MOQS[OP], Prostar 190 and 8MINT8 like this.
  9. Jun 7, 2018 at 11:24 AM
    Wintyfresh
    Ramona, CA
    I don't think there's anything preventing you from using quick-disconnects on the TRD bar, just might involve a little fabrication.
    MOQS[OP], Black Wolf and 15whtrd like this.
  10. Jun 7, 2018 at 11:31 AM
    15whtrd
    15whtrd Mr. Blonde
    I just want someone to do before me haha. And then take really good pictures with a great write up. List of all the parts and where the hell they strapped there sway bar when they were disconnected.
    I really like my sway bar. It corners so much better and the tire wear on the outer front tires has dropped tremendously.
    @TRD15559 removed his front sway bar. He has ADS suspension and he says his truck gets really squirrley on the highway over 90 mph.
  11. Jun 7, 2018 at 11:33 AM
    Wintyfresh
    Ramona, CA
    Alright, lemmie finish up the suspension and I'll see about making some swaybar disconnects before desert season starts. :)
  12. Jun 7, 2018 at 11:34 AM
    15whtrd
    15whtrd Mr. Blonde
    :thumbsup::yes:
  13. Jun 7, 2018 at 11:36 AM
    Correct. You should be able to use quick disconnects on the TRD. Myself..I prefer the Helwig over the TRD because it is adjustable. My.02
    Prostar 190 and 15whtrd like this.
  14. Jun 7, 2018 at 11:39 AM
    THIS^^^"Quick" disconnects. As far as off roading...anything that will bind up the rear end with the sway bar attached. Unimproved trails could be dicey. Depends where you go.
    Prostar 190 likes this.
  15. Jun 7, 2018 at 11:40 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I jumped on the TRD bandwagon too quick on that one. Had I actually researched a little further and known about the helwig adjustability I might of gone that route.
  16. Jun 7, 2018 at 11:42 AM
    The TRD doesn't suck. The Helwig is about the same price but not painted red. I think grey...as in MGM!...haha. Had to do that..sorry...
    Prostar 190 and 15whtrd[QUOTED] like this.
  17. Jun 7, 2018 at 11:47 AM
    15whtrd
    15whtrd Mr. Blonde
    :rofl::rofl:
    Man I wouldn’t have it any other way around here!
    I guess to stroke your ego here. This being my first white vehicle ever I liked a pop of color amongst all the white and black.:anonymous:
    Don’t forget chrome! Lol
    I guess I was going for vanity. I have the TRD Center caps with red letters and the red 4 x 4 sticker on the side. I had plans of eventually doing my tow hooks red as well.
  18. Jun 7, 2018 at 11:58 AM
    Most of the 4X4s I've owned over the years were...........WHITE!
  19. Jun 7, 2018 at 12:12 PM
    :eek::eek: ............ Ssssshhhhhhh ........Don't say that shit out load........you will give them ammo.:D
    Black Wolf[QUOTED] and 15whtrd like this.
  20. Jun 7, 2018 at 12:15 PM
    15whtrd
    15whtrd Mr. Blonde
    ;):yes:
    Black Wolf likes this.
  21. Jun 7, 2018 at 12:17 PM
    15whtrd
    15whtrd Mr. Blonde
    Actually as much crap as we all talk about the color of our tundras and whose is better. I would take anyone of your trucks, in any color and rock the shit out of it! It’s probably because we don’t have anything else to bitch about because of the minimal amount of issues these trucks have. Gotta find something to fight about.
    Black Wolf and gosolo like this.
  22. Jun 7, 2018 at 12:25 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Super White is like having the only loaded gun at a rumble where everyone else just has a pocket knife.
    We don’t need more ammo!
  23. Jun 7, 2018 at 12:26 PM
    15whtrd
    15whtrd Mr. Blonde
    :rofl::rofl::rofl:
  24. Jun 7, 2018 at 12:29 PM
    I decided I wanted a real color.....[​IMG]
    Edit..Just realized there are politicians in the pick...oh well.....
    Prostar 190[QUOTED] and gosolo like this.
  25. Jun 7, 2018 at 12:31 PM
    So TRUE. Shit..we even talk about sway bar differences and their freakin color.....
  26. Jun 7, 2018 at 4:11 PM
    MOQS
    Gary
    Missouri
    Back to the subject at hand please.
    QuickSand rocks the house!
  27. Jun 7, 2018 at 4:27 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I offroad with the rear bar connected going through slow technical stuff and high speed runs. Haven't had a problem from the bar being installed, only thing is I've caught some crap on it and its been sitting on the ground a few times but no damage.
  28. Jun 7, 2018 at 5:23 PM
    OK...Buy a beefier adjustable Helwig sway bar...get quick disconnects...problem solved.
    Prostar 190 and MOQS[QUOTED][OP] like this.
