Rear sway bar removal OEM Bolt Torque Spec
Discussion in 'General Tundra Discussion' started by FlipMonkey21, Nov 3, 2021.
  1. Nov 3, 2021 at 7:30 AM
    FlipMonkey21
    FlipMonkey21 [OP] New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    So I'm planning on removing the rear sway bar this coming weekend. Does anybody know what the torque spec for the bolt that connect to the frame? Thank you.
  2. Nov 3, 2021 at 7:37 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    think it is 84 ft lb on the frame bolts, 48 for the others.
    FlipMonkey21[OP] likes this.
