Rear trd sway bar with lift- shackles at 1.5"?
Discussion in 'Suspension' started by Fsmith6505, Mar 11, 2020.
  1. Mar 11, 2020 at 2:28 PM
    Fsmith6505
    Fsmith6505 [OP] New Member
    2019 Tundra platinum
    Hello all, my lift is getting installed and the installer just texted and said the trd sway bar
    is for factory height so he can't install it. I'm wanting shackles at 1.5" Is this true?
  2. Mar 11, 2020 at 2:39 PM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I’m doing it at stock setting with 1.5” shackles and it works fine. Instead of mounting on the bottom of the axle, they can rotate it up 90 degrees to the back of the axle, as many do, for lifts.
    15whtrd likes this.
  3. Mar 11, 2020 at 3:07 PM
    13Tundra13
    13Tundra13 New Member
    There are many that have it installed with a lift.
  4. Mar 11, 2020 at 3:10 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    It will work. I’m using CB 3 which I think is 1.75. Just had them use some exhaust hangers with extra holes to adjust the exhaust and mounted the RSB with the u bolts parallel to the ground.
    focal likes this.
  5. Mar 11, 2020 at 3:13 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Mines installed fine with 2” shackles. The sway bar needs to be removed to do the install on the shackles tho.
    15whtrd likes this.
  6. Mar 11, 2020 at 4:23 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    I'm currently running front and rear trd sway bars on a bds 7" lift kit plus coachbuilder shim and shackle kit for total lift of 8.5" with no issues. They make a sway bar extension kit if you are going to high of a lift as well
  7. Mar 11, 2020 at 5:13 PM
    4Runner
    4Runner New Member
    Columbia, SC
    Not sure lift is the issue. I heard the same from my trusted crew but luckily I have a good relationship with them and shared the posts here.
  8. Mar 12, 2020 at 12:27 PM
    Fsmith6505
    Thanks the pics were very helpful, sent to my installer and he got it on there.
    focal and SC_TRD like this.
  9. Mar 12, 2020 at 2:46 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks killer!
  10. Mar 12, 2020 at 10:20 PM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Should work. I’ve got Trd duals, 1.5” shackles and trd rsb. No fitment issues at all.
    PeakIT likes this.
  11. Mar 25, 2020 at 12:35 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Where can I get the adjustable end links for lifted trucks? I think I'll need it as I'm almost 8" lifted
  12. Mar 25, 2020 at 12:47 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Check bds. That's were I got mine
  13. Mar 25, 2020 at 12:49 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Which bar are you using?
  14. Mar 25, 2020 at 12:53 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    My sway is the stock red trd. Not sure the extension when I was ordering my bds 7" kit they asked me if I had a sway bar and they gave me the part I needed. Well at a cost I'm sure.. sitting at 8.5 total inch up front and about 8 3/4 in rear and they still work with the extension for the 7" lift they sent me
  15. Mar 25, 2020 at 12:54 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Gotta pic of your setup?
  16. Mar 25, 2020 at 12:55 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Of course ours cost the most lol
    Inquiringone likes this.
  17. Mar 25, 2020 at 1:11 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
  18. Mar 25, 2020 at 1:14 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sorry, I meant rear sway bar.
  19. Mar 25, 2020 at 1:15 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I’ve had a 1.0” block and Boss Toytec rear shocks /w reservoirs
    2.5 lift in front
    TRD sway bar and it worked without any modes to the sway bar kit.
    texasrho83 likes this.
  20. Mar 25, 2020 at 1:17 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
  21. Mar 25, 2020 at 1:31 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You dont have the adjustable links on this one.
  22. Mar 25, 2020 at 1:34 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    No the rear has alot of movement and can be adjusted on it's own quite a bit so I dont think it's as necessary as the adjustability of the front
  23. Mar 25, 2020 at 1:39 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I was under the impression the bar and the end link junction should be at a 90 degree angle.
  24. Mar 25, 2020 at 1:52 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Not sure the exact specs. But since I had the bds 7 kit installed I've since installed shackles for additional lift. So that could be the reason its not lined up as well as it should? I havent noticed a difference tho so it doesn't worry me any
  25. Mar 25, 2020 at 2:23 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've seen ppl move the bar from the bottom to the front of the axle. So the bar would be a little bit below the fill plug of the diff. That takes up some of the slack I think
