Rear Turn Signal Resistor Harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by pman9003, Jan 17, 2021.
  1. Jan 17, 2021 at 5:31 PM
    pman9003
    pman9003 [OP] New Member
    2020 Platinum 4x4
    Posting this up for anyone that has the same OCD as me when it comes to vehicle wiring.
    Unlike the front turn signals, there aren't any LED bulbs (to my knowledge) that integrate a resistor for the rear turn signal bulbs. In other words, for the rear turn signals you must use a resistor in order to prevent hyperflash.
    Now the problem I have with adding resistors is typically installation requires a scotchlok connector or t-tap connector. Personally I hate both of these solutions because they damage the insulation on the factory harness and are generally just not that great.
    So I built a "patch harness" that allows me to connect a VLED VLR-6 without doing any permanent changes to the truck's wiring. The picture is of the almost finished harness, I am terrible about remembering to take pictures once I start working on something. Last step was adding some looming to protect the wires. Basically this plugs in between the taillight and the harness on the truck to add the resistor without any cutting, splicing, etc. Some of you may think this is unnecessary, but for it was well worth the minimal cost and time to preserve the integrity of the factory wiring.
    For anyone interested in doing something similar. Please be aware that this requires some skill in soldering or a $400+ crimp tool. Obviously, you can use any resistor you like and there are different ways of incorporating it into the patch harness. I ended up making mine like this based on the components I had on hand from a VLED order.
    https://www.corsa-technic.com/item.php?item_id=747
    https://www.corsa-technic.com/item.php?item_id=1044
    https://www.corsa-technic.com/item.php?item_id=429
    831Tun, junior and matictundra like this.
  2. Jan 17, 2021 at 5:43 PM
    I wish I knew this a couple of months ago when I installed mine. I'm not fond of those crimping splices either.
  3. Feb 1, 2021 at 2:00 PM
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    This is exactly what I wanted to do. Do you mind sharing with me what your order looked like so I can see each part number for wires, seals etc. Thanks so much.
  4. Feb 1, 2021 at 2:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I have been considering doing the exact same thing, but just hadn't gone far enough to sort out what connectors I needed yet. So thank you for that!
    I've got a crimping tool that cost way less than $400 for doing these terminals.
    Now I've got to decide what to use for resistors - the cheap ones that came with my Auxito front signal bulbs (that I didn't need to use), or buy a set of the VLED ones. The VLED ones come with the disconnect plug, but I could also build one of those using these connectors just as easily...
  5. Feb 1, 2021 at 2:15 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    How much for a set and ship to 85286?
  6. Feb 1, 2021 at 2:27 PM
    NuTundra18
    Jimmy
    I just ordered everything up for $28 shipped from CORSA-Technic. I also ordered the VLED resistors for $30 for (2) 6 ohm with duo-tap connectors which will cut off the ends of duo-tap and solder in place. I already have their red LED 921 bulbs. I will let everyone know how it goes.
  7. Feb 1, 2021 at 3:29 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    Interesting... What year is your truck?
    So I went with the Diode Dynamics XP80 LEDs for all the rear lighting (stop/tail, turn, and reverse) as well as front turn signals on my '21; and didn't have to add resistors. For comparison, on my girlfriend's '21 Tacoma, we used the same bulbs and did have to add resistors.
  8. Feb 1, 2021 at 5:31 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Nice. I made a harness very similar to this back when I installed VLEDs in the truck, after figuring out that replacing the wiring harness to the rear tail lights meant replacing the harness all the way back up to the front (basically requires removing the bed and cab from the frame)
  9. Feb 1, 2021 at 5:38 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I made the same harnesses last June. I avoid hacking oem wires whenever possible
    rockmup likes this.
  10. Feb 3, 2021 at 8:42 PM
    pman9003
    2020 Platinum 4x4
    The connectors include the pins and boots. You just have to select the right size based on the gauge of wire you are using. I used 16AWG so I went with the middle size for the pins and boots.
    Any resistor sold for correcting hyperflash should be good. I think the VLR-6 I used is 25W, which is common for these applications. As far as connecting it to the harness, I wouldn't say the connector helps any. You could easily solder it into the middle of the harness or use butt splice connectors.
    Yeah, the only crimp tools I have wouldn't work. The $400 tool is what they recommend for these, but I am sure there are others that would work, I just didn't care enough to find one and buy it. I'll have to get a nice one eventually for working on my track car.
    I am not planning on making these to sell. Sorry.
    It should work fine for you, just make sure you confirm the polarity before putting the taillight housing back in place. If you have any questions, post them up.
    Mine is a '20 Platinum. I would guess that the bulbs you are using had enough resistance to properly load the circuit in your Tundra. I am using the VLEDs linked below and had hyperflash without the resistors.
    https://www.vleds.com/shop-bulb-numbers/921-led/921-6-r.html
  11. Feb 3, 2021 at 8:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I’ve got the connectors coming. I think I’ll just solder the resistors I have right into the harness for simplicity.
    The crimper I have is the Hozan P-706 shown here:
    https://www.amazon.com/Hozan-P-706-Open-Barrel-Crimper/dp/B002TKG11G
  12. Feb 3, 2021 at 8:55 PM
    pman9003
    2020 Platinum 4x4
    Let me know how that crimper you have works for these. I'm curious as its a different design from what you typically see.
  13. Feb 3, 2021 at 9:10 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I’ve been using it for doing connectors like these since 2015. I just did my OEM LED bed lights using it on the same style of connectors (Yazaki 090 waterproof) to modify the harness that came with them to tap in an extra switch in the bed and route that down to the same plug as the one light.
    It takes a little finesse to get used to doing the really small connectors (22 and 24 AWG like the AMP 025 connectors), but it’s got separate round “crimp” spots for different insulation sizes and those work great on the waterproof seals too.
    rockmup likes this.
  14. Feb 3, 2021 at 9:26 PM
    pman9003
    2020 Platinum 4x4
    Well I just ordered one....
    Thanks for the recommendation!
    RainMan_PNW[QUOTED] likes this.
  15. Feb 4, 2021 at 4:47 AM
    NuTundra18
    Jimmy
    Thank you. When you say polarity, isn’t it just a two wire harness which will allow the resistor wires be installed in either order? Or did you mean to line the wires in the pins correctly in each side? Thanks for your help.
  16. Feb 4, 2021 at 6:38 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Most of the LED bulbs have polarity. If you put it into the bulb socket and it doesn’t work like it should, pull it out and turn it 180 and then test it. It’s best to do that before you actually put the whole taillight assembly back into the truck.
  17. Feb 4, 2021 at 6:42 AM
    NuTundra18
    Jimmy
    ahh, completely makes sense, thank you!
  18. Feb 19, 2021 at 11:53 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Do you have a link for the rear turn signal bulb?
  19. Feb 20, 2021 at 12:57 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for posting. Nice to know where to find those connectors as I'm planning on making tail lights soon..... maybe.
  20. Feb 21, 2021 at 6:14 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
  21. Feb 21, 2021 at 1:11 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    Ironically enough, this morning I had the hyperflash, only on one side, and only for about 10-15 total flashes, then back to normal...
  22. Feb 21, 2021 at 1:17 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Great info here
  23. Feb 25, 2021 at 10:35 AM
    pman9003
    2020 Platinum 4x4
    Was that with the LED bulb? I have had this happen on my 100 series with halogen bulb that was nearing the end of its life. With an LED the only thing I could think of is it was cold, thus lowering the resistance. After 10-15 flashes the temperature went up enough to raise the resistance enough for the truck to not have hyperflash. Another possibility would be a slightly loose connection.
  24. Feb 25, 2021 at 11:16 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    It was with the LED, and it definitely wasn't the coldest temps I've used a turn signal, nor was it the first set of flashes... Either way, I'm chalking it up to an anomaly or slightly loose connection
