Rear wheel bearing replacement parts
Discussion in '2.5 Gen Tundras (2014-2021)' started by Localhost3030, Jun 26, 2023.
  1. Jun 26, 2023 at 1:59 PM
    Localhost3030
    Localhost3030 [OP] New Member
    2016 Tundra SR5 DC 4x4
    I recently replaced both rear axles on my 2016 DC 5.7L with tow package (99500 miles). I bought it used from a dealer so I don't know what the last guy hauled, but most of the 15k miles I've put on it are from towing a 6000lbs travel trailer. The driver side bearing was trashed and the inner seal on the pass side was leaking.
    I went with the Dorman "drop in" axles because all I could find were hub assemblies for almost the same price. For those keeping score at home I did buy Toyota inner seals and O-rings.
    A neighbor keeps telling me his son in law replaces just the rear bearing and reuses the hub on the same year Tundra "all the time at work". Which is all well and good but A - I can't find just the bearing online and B - he never seems to remember to ask SIL where to buy just the bearing, or what the part number is (i.e. I'm suspicious of my neighbor's claim)
    Am I missing something in my google search? Can we replace just the bearing in a 2016 rear axle?
    [Edited to clarify that I can find the hub assembly online but cannot find the bearing outside of the hub assembly]
  2. Jun 26, 2023 at 2:17 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Have you asked the dealer part department? I don’t see why they wouldn’t sell just the bearings. But I have seen weirder things. Also the OEM bearing should have a number and easy to find if you get that number.
  3. Jun 27, 2023 at 4:23 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
  4. Jun 27, 2023 at 6:45 AM
    Localhost3030
  5. Jun 27, 2023 at 7:52 AM
    Localhost3030
    I haven't called around, but the exploded diagram for the rear axle only shows the hub assembly, plus seals and retaining clips
    https://autoparts.toyota.com/products/product/bearing-assy-rr-axl-424600c011
  6. Jun 27, 2023 at 11:45 AM
    pursuit2550
    Now I see what you mean. I have never done rear bearings on a Tundra so that why I found it strange. Normally the bearing is in the diff. The Tundra uses a bearing assembly. Either way there has to be a number on the bearing but the issue is getting that number.
  7. Jun 27, 2023 at 1:25 PM
    agrestic1
    2016 CrewMax
  8. Jun 27, 2023 at 1:27 PM
    agrestic1
    2016 CrewMax
    When I had my F150 it had outboard bearings and seals that I replaced.. & there are also bearings in the diff
  9. Jun 27, 2023 at 2:48 PM
    Localhost3030
  10. Jun 27, 2023 at 4:07 PM
    Most vehicles no longer have “just the bearing”. They have a bolt in bearing and hub assembly that simplifies the process. Your neighbor could just be FOS. I wish my 2000 Tundra had front hub/bearing assemblies. Instead I have to find a 50 ton press and go through the nightmare that is pressing all the various parts of the bearing in and out.
  11. Jun 27, 2023 at 4:23 PM
    Localhost3030
    I also vote FOS buuuuuut figured I'd ask since I wasn't seeing anything like that at all. I think I much prefer the hub assembly to what I've seen on YouTube.
  12. Jun 27, 2023 at 4:44 PM
    pursuit2550
    Like I said, the bearing could be found, but you need the number that’s in it. If you look at rockauto, in some pics you can see a manuf number. With that number you can buy just the bearing. I work in an industrial plant and we order bearing all the time for equipment. The bearing in the hub assy is available out there, you just need the number. But after seeing the price, I don’t see a big saving there. You have to pay someone to remove and install the bearing. You need a press for that. Me personally, avoid the headache and buy the assy.
  13. Jun 27, 2023 at 4:47 PM
    pursuit2550
    Also rockauto has some good manuf for those assy, so you could go that route to save some. OEM will have one of those bearing manuf on rockauto. SKF,Timken, Kojo, etc.
  14. Jun 27, 2023 at 4:48 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Use it then return it :laugh:
  15. Jun 27, 2023 at 4:55 PM
    They have a manual 50 ton press for more like $300. Waiting for it to go on sale. And offer a coupon.
  16. Jun 28, 2023 at 3:10 PM
    agrestic1
    2016 CrewMax
    And don't forget the seal. Looks to come with the hub bearing module assy...
