Rear Window While Parked
Discussion in '3rd Gen Tundras (2022+)' started by SquitoMan, Apr 20, 2023.
  1. Apr 20, 2023 at 12:38 PM
    SquitoMan
    SquitoMan [OP] New Member
    2022 Army Green TRD Sport
    I’ve noticed that when I’m parked and I roll the rear window up the truck puts out a single tone beep for about 10seconds. Any idea what this is? Is it just to let me know my window is up?
    Anybody else experience this?
  2. Apr 20, 2023 at 5:45 PM
    Troyboy84
    Troyboy84 New Member
    BC Canada
    2022 SR5 TRD Offroad
    I just had my truck in for the excessive wind noise and also mentioned the same issue. They said they checked 4 other new tundras and they all made the same noise. No other explanation, just that it is consistent across all the trucks. I noticed it when I was pulling out of my driveway, saying goodbye to my wife and dog out the back window and then rolled it up, quite loud and noticeable from inside and outside the truck.
  3. Apr 20, 2023 at 6:00 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    The rear window is not equipped w/jam protection like the side windows and sunroof are, so my guess would be that it's a warning tone to let everyone know the window is closing and to keep clear to prevent injury.
  4. Apr 20, 2023 at 7:49 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    It only does it when the window is at the end of travel. I noticed one day. My windows were up and I was playing with the back window. I could hear the slightest beep when the window was all the way up. I thought I was hearing things. Did it a couple times and realized what it was doing. Being so faint to me, was like when you get ringing in your ears. Then I tried to make it do it and it wouldn't.
  5. Apr 22, 2023 at 5:45 PM
    nodak67
    nodak67 New Member
    JR
    do you have the beep volume setting set low in the big screen?
  6. Apr 22, 2023 at 6:48 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I know it's not all the way up. Maybe 1up from lowest setting.
  7. Apr 22, 2023 at 6:59 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    If it beeps when all the way up, can someone stick something in the way, like a rolled up towel, shoe, piece of foam etc and see if it beeps with an obstruction in the way, before all the way closed?
    I'm curious if it's pressure sensitive and let's you know if something is in the way.
  8. Apr 22, 2023 at 7:55 PM
    Hella Krusty
    Hella Krusty New Member
    If I was a betting man.....I would bet it beeps so when driving you do not have to take your eyes off the road to check and see if it is closed.....truck is letting you know. Its all i got LOL
    SnrDisregardo likes this.
  9. Apr 28, 2024 at 12:08 PM
    DeaG
    DeaG New Member
    SF Bay Area
    2024 Lunar Rock Tundra Limited TRD OR
    Has anyone figured out how to turn this beeping off?
  10. Apr 28, 2024 at 2:00 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I have had my rear window down a couple of time and I didn’t hear any beeps when rolling it back up.
    Xcumminsguy likes this.
  11. Apr 28, 2024 at 2:07 PM
    DRP
    DRP Old Member
    Dave
    No beep for me either on rear window. There was another thread a week or two ago on this. Same thing there, some have it some don't.
  12. Apr 28, 2024 at 2:34 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Wonder if it’s a Canada requirement. Not sure where the OP is located though.
  13. Apr 30, 2024 at 1:39 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Only get a beep if leave window down after shutting truck off. Just let's you know a window is left open, same with sun roof.
  14. Apr 30, 2024 at 1:46 PM
    DeaG
    DeaG New Member
    SF Bay Area
    Yeah I get those notifications on the dash with the open windows too but it's more of an "external" beep when closing the rear window right after parking and before any doors are opened.
  15. Apr 30, 2024 at 1:55 PM
    Tundrastruck91
    Copy, yeah never had that happen.
  16. Apr 30, 2024 at 2:59 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Yes, both my son's and my truck do it, but only at low speeds or at a stop. If I roll it up while cruising down the road, it doesn't do it, but if I'm pulling into the driveway or already parked, it beeps. We can't figure it out either. Another Toyota quirk I guess.
  17. May 1, 2024 at 10:05 AM
    osu1978
    osu1978 New Member
    My 2023 pro rear window does not ever beep so it’s either a setting that is turned off or I am more deaf than I thought.
    Tundrastruck91 likes this.
  18. Jul 25, 2024 at 8:17 AM
    Azrsx
    Azrsx New Member
    2023 tundra blueprint limited
    It did this to me last night in the drive thru line. Thought the truck wanted some food too
  19. Jul 25, 2024 at 8:56 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I think you have to be in gear for it to beep.
  20. Jul 25, 2024 at 5:25 PM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    I’ve never heard a beep while operating the rear window, but I have poor high frequency hearing.
    On a side note, does anyone find it weird how they wired the rear window switch — push up to have window go down — pull down to have window go up.
    Seems backward to me…
  21. Jul 25, 2024 at 5:38 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Rear window switch operates exactly the same as the rest of them. It’s just facing down. Push to open and pull the close is how you should think about it.
  22. Jul 25, 2024 at 6:05 PM
    Retired...finally
    It's to let you know to turn around and go back to the outfitter to get a new fishing rod to replace the one the window just chopped in two.
  23. Jul 26, 2024 at 7:16 AM
    Gonefishingdave
    Dave
    Central New York
    Now that I look at it in that context, it makes more sense. Thanks!
