Rebuilding Front Seats
Discussion in '1st Gen Tundras (2000-2006)' started by pollymath, Mar 26, 2023.
  1. Mar 26, 2023 at 9:02 AM
    pollymath
    pollymath [OP] New Member
    2006 Limited DC 4x4 "Chunky Salsa"
    I've got an 06 Limited with heated leather seats.
    The uppers and passenger seat are in great condition, but the driver's lower is trashed. Most of the outside seat bolster has completed deteriorated.
    What's the easiest and/or cheapest way of rebuilding the lower seat cushion with a new cover? Just purchase used on ebay? Does someone make new foam and covers?
  2. Mar 26, 2023 at 10:25 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    FrenchToasty likes this.
  3. Mar 26, 2023 at 11:15 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Find someone local, an upholstery shop if you don’t care about the color match. I had seat bottoms done in my Tacoma for under 100$
  4. Mar 26, 2023 at 11:22 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  5. Oct 2, 2023 at 1:36 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    They do not have the foam cushion for the 2006 tundra double cab.
    do you know of any others? I’ve been researching for a while now.
    The only local upholstery shops were only willing to do it if they recovered my seats. They were both very small mom and pop style and sounded like they were pretty much going to wing it and they seem to indicate that would be the most difficult part of the Upholstery
    there is a place nearby that produces upholstery foam. I’ve got tools to cut it if I knew the dimensions. mine is in such bad shape I’m not sure if I could use the current one as a template. Maybe I could since it’s only on the left side on the driver seat, both upper and lower. I suppose I could guesstimate using the side that is still intact
  6. Oct 2, 2023 at 5:37 PM
    w666
    Maryland
    Well...there's always the OEM option:
    https://toyotaparts.bochtoyotasouth...006-toyota-tundra-seat-cushion-pad-715120c030
  7. Oct 2, 2023 at 8:52 PM
    Weagle
    Prattville, AL
  8. Oct 3, 2023 at 1:58 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I had a local lady that came highly recommended for upholstery stop by to look at my old vinyl bench seat in another truck. She quoted me $800 if I brought her the bench. I thought it was high and never did it. $100 sounds like a killer deal for seat bottoms.
    Weagle likes this.
