Recommendations for tire pressure on ridge grapplers 285 70 18?
Discussion in 'Wheels & Tires' started by Gears, Apr 22, 2020.
  1. Apr 22, 2020 at 10:28 AM
    Gears
    Gears [OP] New Member
    Ontario Canada
    4th Gen Tundra 5.7 SR5 TRD Offroad
    Grill, Bak flip MX4 bed cover, under seat sub unit, more to come.
    Ideas anyone? Thanks.
  2. Apr 22, 2020 at 11:37 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    40 psi on the road. 25 off road. More for towing.
    Ely010606 likes this.
  3. Apr 22, 2020 at 11:38 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    45 front, 35 rear and adjust depending on terrain or payload.
    Hbjeff likes this.
  4. Apr 22, 2020 at 11:43 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Do a chalk test, takes 20 minutes and you will then know the right pressure for your particular truck, setup, load.
  5. Apr 22, 2020 at 11:44 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Shit 25 isn't offroad pressure, that's street pressure on some of my trucks lol
    smslavin likes this.
  6. Apr 22, 2020 at 11:50 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Email Nitto with truck info as well as tire and wheel info and they will give you a starting point. Be specific as possible so specify crew vs double cab. If aftermarket wheels size, width, backspace, and offset. Anything you can think to tell them.
  7. Apr 22, 2020 at 11:54 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    44 at all 4 corners.
    Tundra234 likes this.
  8. Apr 22, 2020 at 12:05 PM
    Gears
    Ontario Canada
    Will do thx guys.
  9. Apr 22, 2020 at 12:18 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2, 40 psi on all 4 on mine
  10. Apr 22, 2020 at 12:23 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    All 4 corners are 38 on mine.
  11. Apr 22, 2020 at 12:51 PM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    I run cold pressures of 44 front and 39 rear in mine. When towing or hauling a significant load, I will raise the rear pressure. These 5.7 motors are heavy...you need more pressure up front when empty. Like others have said, do the chalk test to confirm.
  12. Apr 22, 2020 at 3:57 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Yeah I get it, but so far I don’t have an air compressor so I drive it home on whatever I’m running and I mostly drive forest roads instead of full on off-road tracks (a bit hard to find an unmaintained road that’s open around here).
  13. Apr 26, 2020 at 7:13 AM
  14. Apr 26, 2020 at 7:14 AM
    I run 44 psi on all corners as well.
  15. Apr 26, 2020 at 7:44 AM
    spdrcer26
    spdrcer26 New Member
    Bakersfield, CA
    2017 Crewmax
    I run 40 on all fours unless I am taking a trip over 300 miles with the back loaded down then I bump the rear up to 45
  16. Apr 26, 2020 at 12:57 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
  17. Apr 26, 2020 at 1:20 PM
    11CMGray
    11CMGray New Member
    Chalk test will be pretty accurate
