Recon Big Rig Ice lights
Discussion in 'Lighting' started by RNMedic964, Jul 29, 2023.
  1. Jul 29, 2023 at 12:01 PM
    RNMedic964
    RNMedic964 [OP] New Member
    Scott
    2023 tundra
    Alright I installed these on a 23 platinum tundra. The turn signal and driving light functions work fine. But I need help figuring out the courtesy light feature. They’re supposed to come on when you unlock the truck or open a door.
    I have tried tapping into the dome light fuse. The lights come on but never power off. After the dome light goes off they stay on.
    I tried wiring to the rear cargo light, same result. Also tried the little courtesy light that shines on the floor. Same result. No matter where I wire them the white lights stay on all the time and never power off.
    I would really appreciate any ideas on how to get this feature to work, it’s literally the entire reason I purchased the lights. Thank you in advance.
  2. Aug 1, 2023 at 5:13 PM
    RNMedic964
    Scott
    2023 tundra
    Still hoping for an answer to this
  3. Aug 3, 2023 at 11:13 AM
    WayneMcD
    WayneMcD New Member
    Wayne
    Georgia
    2022 Tundra Platinum CrewMax, Metallic Gray
  4. Aug 3, 2023 at 11:38 AM
    RNMedic964
    Scott
    2023 tundra
    Unfortunately it’s not that easy on the 23 Tundra. The dome light is a ground controlled circuit. So the hot wire is always hot. The circuit is controlled on the ground side. Basically to turn the dome light on the ecu only makes a ground when the dome light is on. So it always has power it just doesn’t always have a ground. So wiring these lights up to the done light positive wire makes the leds stay on all the time. I believe I’m going to have to add a relay, I just have to figure out how.
  5. Aug 3, 2023 at 12:40 PM
    WayneMcD
    WayneMcD New Member
    Wayne
    Georgia
    What about using the trailer light harness or the wires that go to the harness? I would think they ran under the truck and up into the cab at some point.
  6. Aug 3, 2023 at 1:37 PM
    RNMedic964
    Scott
    2023 tundra
    I’m actually going to put a circuit tester on those wires to see if that location will work. I actually spoke to recon and they advised me that in this scenario I will need to install a 5 pin relay and sent me a wire diagram of how to install it. I picked up a relay at advanced auto so if the trailer wire doesn’t look as if it’ll work the realy will be next.
  7. Aug 8, 2023 at 1:28 PM
    PickupMan2008
    PickupMan2008 Gladys Knight Industries Two Thousand
    Quentin
    Orange City, FL
    2008 Black Double Cab 4x4 5.7
    Cover King seat covers, weathertech rain guards and floor mats NFab Light Bar w/ KC Lights 2010 Limited Grill mod topper bedrug Amazon tailgate handle with rear backup camera still working on mods
    If you did this, could you have them blink with your blinkers?
  8. Aug 8, 2023 at 2:17 PM
    WayneMcD
    WayneMcD New Member
    Wayne
    Georgia
    Depends on the lights you get. I have not actually installed mine yet, waiting on a few items to get delivered.
  9. Aug 21, 2023 at 6:46 PM
    Zzooomm
    Zzooomm New Member
    So, do it just like the dome light. Hot wire to the light and control the ground from the dome light. Just a thought.
  10. Aug 21, 2023 at 6:57 PM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    David
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
