Red button on seatbelt sticking
Discussion in '1st Gen Tundras (2000-2006)' started by Jonny Rotten, Jan 8, 2022.
  1. Jan 8, 2022 at 11:27 AM
    Jonny Rotten
    Jonny Rotten [OP] New Member
    It's becoming a pain to buckle seatbelt. The button stays stuck in most of the time and it won't lock.
    I don't want to spray wd40 or lithium grease in it because I'm sure it will end up on my clothes from the belt sliding across me
    Any ideas?
  2. Jan 8, 2022 at 12:35 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe try cleaning it out with some brake cleaner? I like silicone spray lube because it dries, for situations just like this.
    Jonny Rotten[OP] and 1lowlife like this.
  3. Jan 8, 2022 at 1:06 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Jack McCarthy and 1lowlife like this.
  4. Jan 8, 2022 at 1:40 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Maybe spray some cleaner (409 or whatever), let it sit a few minutes, wrap it in a towel, and blow it out with compressed air.
    I like @15whtrd suggestion as well..
    15whtrd likes this.
  5. Jan 8, 2022 at 1:45 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I did all that on mine and it helped a little bit, but didn't really fix it. The thing that fixed it though was to bend it around so it was pointing downward and tapping it on the side with a screwdriver handle. Some little piece of debris had fallen into it and was jamming up the mechanism.
  6. Jan 9, 2022 at 4:29 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    You could try plastic SAFE contact cleaner. It will clean any sticky grime and not leave any oily residue, protect the surrounding fabric or whatever seat material. Then very small amount of silicone spray, that will also help things move, again without any oily residue. Make sure anything you try is plastic safe. CRC makes one, and is readily available at most hardware stores. The silicone spray alone might help it things aren't too grimy.
    Jonny Rotten[OP] likes this.
  7. Sep 10, 2024 at 3:18 PM
    I'm re-posting this video in a few different threads to spread it around. I had the worst time trying to find it a minute ago.
    This video shows how to tear Toyota bucks apart and repair, swap internals, fixing broken circuit in the meantime. Props to @VR6T for finding it. Jump to roughly 4m30s to see where disassembly really begins. A lot of what comes before is referential fluff.
    FishNinja and Jack McCarthy like this.
  8. Sep 10, 2024 at 4:28 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Very interesting. My drivers side still works even though it’s recessed until you put in the connecting belt. Looks as though only ONE tab is broken and the other is still good.
  9. Sep 10, 2024 at 6:26 PM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    Camburg 4-Link, Bed Molle panels, Pelican cargo bin, TRD drop-in Filters
    Had same issue on my 1st. Gen. Tacoma. Lil' WD40 and back in business...
