Regear/locker cost estimate (SoCal)
Discussion in 'General Tundra Discussion' started by Spvrtan, Feb 9, 2018.
  1. Feb 9, 2018 at 3:44 PM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Does $3,900 out the door (parts and labor) sound fair for front/rear 4.88 Nitro gears and a rear ARB air locker on my Tundra? I'm installing the locker compressor and running the wiring/hose myself before I drop the truck off. I get that the Tundra parts may be a few hundred more compared to Tacoma parts.
  2. Feb 9, 2018 at 6:28 PM
    tmart
    tmart New Member
    Travis
    I’m no expert but that sounds a little pricey to me
  3. Feb 9, 2018 at 6:32 PM
    Grumpy Uncle
    Pat
    CO
    If you haven't bought your parts yet contact Kieth@dirtydeeds, thats who I got mine through. I went with the Auburn not the ARB. I would REALLY contact him if you haven't. Really good price.
    15whtrd and TheBeast like this.
  4. Feb 9, 2018 at 9:23 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    This actually sounds like a good deal. Front and rear ARB lockers alone cost about $2000 just in parts. 4.88 Nitro Gears w/ bearing kit another $1300. That leaves $600 for labor. Let me know how the install turns out. I’m also looking for someone to install my front and rear lockers.
    Marty McFly and BestGen like this.
  5. Feb 9, 2018 at 9:31 PM
    tmart
    tmart New Member
    Travis
    He said just a rear locker
  6. Feb 9, 2018 at 9:42 PM
    Porschetech29
    Francis
    Oops I didn’t realize it was only for the rear locker. Either way let me know how the install works out.
  7. Feb 9, 2018 at 9:54 PM
    tmart
    tmart New Member
    Travis
    So more like 1600 in labor which is a little steep I think. But that set up will be fuckin awesome when it’s done!
  8. Feb 9, 2018 at 9:57 PM
    Spvrtan
    Kris
    San Diego, CA
    Yea, just the rear. So it breaks down to about $1,400-1,500 in labor, taxes, and miscellaneous items like oil.
  9. Feb 9, 2018 at 9:58 PM
    Spvrtan
    Kris
    San Diego, CA
    I can already chirp my 40" tires easily with my supercharger but I'd like even more oomph back with the lower 4.88 gears, especially if I'm going to tow a trailer soon. The 5.29s are taking too long to come out.
  10. Feb 9, 2018 at 10:00 PM
    tmart
    tmart New Member
    Travis
    Might be a tad bit high but if they do quality work I’d pay it. You run 40s on stock 4.30s? That’s crazy, the supercharger helps a lot? I bet you’ll see a huge difference
  11. Feb 10, 2018 at 12:01 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Wow, I thought you regeared a long time ago, guess you've been waiting for the 5.29s. I'm looking to do the same, regear and rear locker..
    joonbug likes this.
  12. Feb 10, 2018 at 12:19 AM
    Spvrtan
    Kris
    San Diego, CA
    Yea, the supercharger helps a ton. I'm not towing yet, which is why I haven't regeared, but I do plan on towing a trailer this year.
  13. Feb 10, 2018 at 12:19 AM
    Spvrtan
    Kris
    San Diego, CA
    Yea, I was waiting but, after hearing from Motive that the front 5.29s are at least another year out at best, I can't wait any longer.
    831Tun[QUOTED] likes this.
  14. Feb 10, 2018 at 1:05 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    Who is doing the work? If it’s not MIT in Santee/ El Cajon, I’d call those guys.
    If it is them, they do the best driveline work in San Diego.
    SAGE63 likes this.
  15. Feb 10, 2018 at 1:25 AM
    Spvrtan
    Kris
    San Diego, CA
    The estimate was from Pro Gear. I know Pelfrey (@socalduckslayer) got their shop Tundra geared at MIT but I'm not sure how much it ended up costing them and whether or not Tyler also put in a rear locker.
  16. Feb 10, 2018 at 5:52 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Seems expensive, parts cost around $2400. My truck is currently at the shop for the rear locker and F/R gears install. They said about 8 hours labor to pull the diffs and install everything or about 6 hours if the diffs were already dropped. I supplied my own parts and this shop charges $75 an hour.
  17. Feb 10, 2018 at 6:55 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    sounds fair to me. cheapest i could find up here was $4500 all in, parts & labor, minus the compressor. i'm planning on installing the compressor myself as well.
    831Tun likes this.
  18. Jun 7, 2022 at 5:51 PM
    greentrbo95gst
    greentrbo95gst New Member
    Huntington Beach
    I don't mean to bring out this thread from the dead, but I need to re-gear for my 37's. Any shop recommendations in Southern California?
  19. Jun 17, 2022 at 7:12 AM
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    get in touch with Jason from Sibi Built getting my Tundra re-gear and lockers next month.
    SAGE63 likes this.
  20. Jun 17, 2022 at 8:08 AM
    shawn3210
    shawn3210 New Member
    Southern California
    What was the cost?
  21. Jun 26, 2022 at 1:56 PM
    greentrbo95gst
    Huntington Beach
    What's the cost?
  22. Nov 21, 2022 at 2:38 PM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    Did you get your re gear done? There is a shop in riverside that is offering regears for 2200(includes labor, doesnt include lockers) right now, even cheaper if you have a tacoma(i think its like 1780). They are called premier west gears. I stumbled upon them in one of the threads. One of the guys got revolution gears(supposedly quieter than nitro) but the also offer nitro gears.
  23. Nov 21, 2022 at 3:35 PM
    greentrbo95gst
    Huntington Beach
    I just had my gears done by the shop in Riverside and it was 2200 with the break-in procedure. They did a good job
  24. Nov 21, 2022 at 3:59 PM
    Gfgneo
    Gfgneo New Member
    California
    How long did it take? I was looking at them but riverside is a long ways for me and with that break in period it will take forever to get home. But that is a really good price. Did you go with nittro or evolution gears? I wanted to get an auburn LSD done as well
  25. Nov 21, 2022 at 4:10 PM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    Check out premier west gears in Riverside. Might be worth the 1.5 hour drive for you. I did 5.29 revolution on a 4x4 for $2200 a couple years ago. Nitro and Revolution were the same price.
  26. Nov 21, 2022 at 7:55 PM
    greentrbo95gst
    Huntington Beach
    Premier Gears and I went with revolution 5.29.
    They had a special where the gears showed up broken in already. It was a drive for me too, but worth it. They were $800 cheaper than OC shops and they have been around for 35 years doing the same thing. It was done same day, but typically with no appt they said it would be a two day turn around.
  27. Nov 21, 2022 at 8:51 PM
    Gfgneo
    Gfgneo New Member
    California
    You got the REM polish? I hear you dont have to do the breakin with that but idk im wearying of that. But i think they offer like a 10 year warranty right? So maybe if i buy that it will give me a piece of mind. Although i think i would probably change out the oil regardless. Did you get the clam shell to replace the needle bearing?
