Remote start recommendations
Discussion in '3rd Gen Tundras (2022+)' started by Chut, Nov 26, 2022.
  1. Nov 26, 2022 at 7:31 AM
    Chut
    Chut [OP] New Member
    I live in an area that doesn't have go cell reception, let alone AT&T (which seems that's what Toyota uses). Since the remote start, whether key fob or obviously app, goes through cell to start the car, it's useless to me. I'm looking for a standalone system that could bypass immobilization. Anyone install a 3rd party remote start system? What do you like/dislike about it.
  2. Nov 26, 2022 at 8:46 AM
    devron11
    devron11 New Member
    Ron
    Denver
    How to remote start Toyota Tundra with key fob or mobile device
    POSTED ON SEPTEMBER 11, 2021 BY NABEEL
    Toyota Tundra supports remote start feature that allows you to remotely start the engine of your vehicle for the purpose of cooling or preheating the interior before the passengers gets to it.
    Toyota Tundra – (photo by Toyota)
    The remote start feature on Toyota Tundra has many benefits. You can start your vehicle in advance when the weather is too hot or cold outside. The system turns on the air conditioning or heating, making inside cabin temperature more tolerable when you get to your vehicle.
    Before you start your Tundra remotely, ensure that the vehicle is parked in a well ventilated area. Starting your vehicle in an enclosed space, like a closed garage, introduces risk of carbon monoxide poisoning.
    Remote start procedure for Tundra
    You can remotely start your Toyota Tundra by following these simple steps:
    1. Press and release the LOCK button twice within two seconds on the key fob of your Tundra.
    2. Then press and hold the LOCK button for three seconds on the key fob.
    3. The turn signal lights flash multiple times and the engine starts.
    4. Once started remotely, the engine will run for 10 minutes and then shut down automatically.
    For safety reasons, the engine will turn off if you open any door on your Tundra when the engine is running after remote start. A valid key must be inside your vehicle to switch the ignition on and drive your vehicle.
    TheGreenGoblin likes this.
  3. Nov 26, 2022 at 9:00 AM
    Chut
    Apparently, still uses cell service with fob. I can start the car in town but not many places I normally travel.
  4. Nov 26, 2022 at 9:17 AM
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    I dont think it uses cell service if you use the fob. I crank mine everyday with the fob and it starts within 3 second of the third button being pressed. If I use the phone it takes 45-60 seconds to crank after sending the request. I believe when the remote connect trial expires after 3 years, the functionality for the fob to remote start will be shutdown by the computer if the service is not renewed. Hopefully Toyota will come to their senses before then or someone will come up with a permanent solution by then.
  5. Oct 22, 2024 at 10:30 AM
    murray01
    murray01 New Member
    Murray
    2024 Tundra Platinum 1794 Crewmax
    none
    How many remote starts will the system allow ?
    Korj26 likes this.
  6. Oct 22, 2024 at 11:06 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    One thing to note. On my 24 I couldn't get it to work. Then I tried pressing once, then a second time within 2 sec. & holding. I was holding on a 3rd press, that didn't work, holding the second press worked.
    75tranzam likes this.
  7. Oct 22, 2024 at 11:17 AM
    Breathing Borla
    Northern Illinois
    @eddiefromcali
    Eddie has a 2 way system I think other than toyota.
  8. Oct 22, 2024 at 11:26 AM
    raylo
    raylo not so new member
    Frederick, MD
  9. Oct 22, 2024 at 11:27 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    :) I do. new guy bumped an old thread, he has his own where hes asking about this...asked him to do a search.
  10. Oct 22, 2024 at 11:57 AM
    DRP
    DRP Old Member
    Dave
    FOB doesn't use cell but you basically have to be within spitting distance of the truck for it to work.
  11. Oct 22, 2024 at 12:01 PM
    eddiefromcali
    Eddie
    100% Stock
    yup...its junk...thats why I went with the accessorides too...works from FAR
