Remove hood scoop to install solar panel
Discussion in 'Lighting' started by TundraJedi, Dec 23, 2023.
  1. Dec 23, 2023 at 10:31 PM
    TundraJedi
    TundraJedi [OP] New Member
    Eric
    2021 Tundra Pro
    Has anyone removed their hood scoop and then installed a Cascadia or Lensun solar hood panel? I would like to see if this is possible. Does the solar panel fit in flush where the scoop used to be, or is there an open space between the solar panel and hood where water and dirt can accumulate? Thanks in advance.
  2. Dec 23, 2023 at 11:00 PM
    RobertD
    Robert
    DFW, Texas
  3. Dec 23, 2023 at 11:16 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Everything I’ve seen, 1) you want to put down a vinyl paint protection film under it - which would cover over the holes left behind from the scoop and 2) the panel is larger than the divot in the hood, which is larger than the hood scoop.
  4. Dec 24, 2023 at 6:37 AM
    TundraJedi
    Eric
    2021 Tundra Pro
    Thanks. Looks like the solar panel will cover the entire area over the hood scoop. And that means there will be an empty space between where the hood scoop was and where the new panel now sits. I don’t think I’m willing to deal with that but will think it over again. Thanks for the help.
