Remove panel behind rear seats in DC
Discussion in '1st Gen Tundras (2000-2006)' started by 2truckornot2truck, May 1, 2021.
  1. May 1, 2021 at 6:15 PM
    2truckornot2truck
    2truckornot2truck [OP] Aspiring Truck Guy
    Felix
    TX
    2006 Tundra DC SR5 V8
    None yet! Does steering wheel cover count? :)
    Hello Tundrites. I promise I tried searching for it first...
    Wanted to remove the panel behind the back seats. Those knobs won’t Budge and I don’t want to break anything. Is there a secret? I see the bolt in the lower center bottom. But I’m sure those knobs at the top are also fasteners.
  2. May 1, 2021 at 6:17 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You pull on the outer edge of the knob and then it will pop out, no twisting needed
  3. May 1, 2021 at 6:23 PM
    2truckornot2truck
    Felix
    TX
    That so? Ok I have tried that
    - I guess I need to pull a lot harder. Back in a few
  4. May 1, 2021 at 6:25 PM
    FrenchToasty
    Mo
    Bone stock
    Don’t put your nails/fingers behind the knob, literally only pull out on the face of the knob
    BubbaW likes this.
  5. May 1, 2021 at 6:29 PM
    2truckornot2truck
    Felix
    TX
    You da toasty man! Thank you. Hope all you are well. Long live liberty.
    EddoHOW and FrenchToasty like this.
  6. May 1, 2021 at 6:44 PM
    2truckornot2truck
    Felix
    TX
    This thing by has a gazillion clips! Wow. I’m sure I only broke like a dozen...
    des2mtn likes this.
  7. May 1, 2021 at 8:02 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Holy crap. On my 2008 it was just a flappy rubber/vinyl curtain hanging back there.
    2truckornot2truck[OP] likes this.
  8. Jun 15, 2023 at 4:15 AM
    PA Tundra
    PA Tundra New Member
    2006 Tundra TRD
    OME Lift, upper control arms, Frame swap
    Does anyone know what these pins are called? Or the part number?
  9. Jun 15, 2023 at 7:50 AM
    Which ones? There are two, the yellow ones and the white round ones.
    The white ones can be bought in any bulk fasteners kit sold on scAmazon. I have a couple of clear tackle boxes full of 'em. I can run down the exact p/n if you really need it.
    Also FYI, it looks like you may have the DC. It looks like you have Kilmat there. Logic tells me you're sound deadening. Note that black panel that already has some deadener on it is, I believe, just a cover for the vertical rear sliding window. You'll definitely want to pop off the black cover with the window up, and hit the back wall with about 3, maybe 4 pieces of the size seen in your photo. Then I'd probably break two more squares in half and do the back side of the black panel. Just my 2¢.
  10. Jun 15, 2023 at 9:21 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As mentioned, the white ones can be bought other than dealer....AutoZone, Advance Auto etc
    As for the dealer part numbers, the white ones are now 6771-06030(gray), which replaced 67771-03050, 67771-06070, 67771-30070. That clip can also be used on other trim locations, in particular door cards.
    Bought a dozen from McGeorge last year for just that use.
    NUDRAT, abcinv and shifty` like this.
  11. Jun 15, 2023 at 4:58 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I was going to say to shop for clips with removing the back piece. I also snapped a few when I was connecting a harness to the factory amp. And I was being careful..
