Removing clear vinyl protective film on hood
Discussion in 'Detailing' started by jaredmillerdvm, Jul 19, 2021.
  1. Jul 19, 2021 at 12:05 PM
    jaredmillerdvm
    jaredmillerdvm [OP] Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Hey guys,
    When I purchased my 2018 the hood had a clear protective film, similar to/or vinyl. Well long story short it’s peeling due to something. I want to remove the protective coat but worried about harming the paint. What would be your recommendations on removing the film without harming the paint/clear coat. What adhesive removers are the best for the job? Thanks in advance.
  2. Jul 19, 2021 at 12:18 PM
    2mchfun
    Warm it up with a hair dryer or heat gun as you lift. First adhesive remover I would try is wd 40. You don't want anything harsh.
  3. Jul 19, 2021 at 12:27 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Look on AmmoNYC on YouTube. He does a whole video on film removal using boiling water.
  4. Jul 19, 2021 at 12:30 PM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Put it outside in the sun and peal it off when its warmed up.
    When your finished rubbing alcohol & or WD-40 will take the glue right off for you.
    If the finish is Toyota factory it wont hurt anything and come right off for you.
  5. Jul 19, 2021 at 4:21 PM
    jaredmillerdvm
    Anderson, SC
    I’m just not sure whatever cause it if it hurt the paint underneath? Guess it really doesn’t matter it has to come off regardless.
