replacement front turn signal bulb?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tacogrande, Aug 14, 2022.
  1. Aug 14, 2022 at 12:35 PM
    Tacogrande
    Tacogrande [OP] New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Today, my Tundra front turn signal bulb stopped working. First problem i have had with the truck since bought new. Can someone please let me know the bulb part number and instructions for replacement? Quick search i found nothing. It is all stock. Thanks in advance.
  2. Aug 14, 2022 at 12:47 PM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    8704558E-8985-4AFA-BDD0-9E94F4C0ABFB.jpg 1221623B-0DED-4D96-8C17-90FB0FB989B6.jpg
    From my 2016 Manual. If memory serves me….the bulb is accessed easily at the back of the headlight assembly under the hood. Just twists out?
    ATHiker, bulldog93 and 1lowlife like this.
  3. Aug 16, 2022 at 1:07 PM
    Tacogrande
    Jeremy
    Thanks. So i still need more help. I went to get replacement bulbs and O'Reileys only had 3157 and it showed direct replacement on their computer and he says if it doesnt work brink it back. So i install it and drive away and two minutes later the turn signal is not working again so i head to another auto parts store and get the 4157 and put it in and it works. Then two minutes later its not working again then i got home and its working again. I see no evidence of any rodent chewing damage on any wiring so whats going on here? The bulb is inserted all the way.
  4. Aug 16, 2022 at 1:12 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The front turn signal/DRL to my 2014 was 3157CK..
    Does your 2016 Limited have amber DRLs or the white LED strip on the bottom of the headlight?
    I don't remember when the white LED strips came out.
    Is it right or right or left and right turn signals?
    Also, is the rear turn signal working?
  5. Aug 16, 2022 at 1:17 PM
    Tacogrande
    Jeremy
    Its SR5
  6. Aug 16, 2022 at 1:46 PM
    Tacogrande
    Jeremy
    I feel dumb. LOL I didnt have it pushed in all the way like i thought i did.
