Replacement fuel door to non locking door
Discussion in '1st Gen Tundras (2000-2006)' started by Orange devil, Jun 9, 2021.
  1. Jun 9, 2021 at 9:43 PM
    Orange devil
    Orange devil [OP] New Member
    Decided to change the 2001 fuel door to 2003 or newer..was a pretty easy swap ..had to chan20210609_184921.jpg 20210608_143607.jpg 20210609_200227.jpg ge out the inner housing as well ..luckily I found all the parts at the junk yard .
  2. Jun 9, 2021 at 9:54 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    That looks pretty kool
    Orange devil[OP] likes this.
  3. Jun 10, 2021 at 3:05 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Can you elaborate on what you did? Do you have a pic with the door open?
    On my '00 locking door, the door/hinge assembly just comes off with two bolts. Did the '03 hinge not match up to the original holes?
  4. Jun 10, 2021 at 6:07 AM
    Orange devil
    Ill get you a picture latter this evening. The 03 matches up to the original holes for the door ,same as my 01 .But the inner housing that has 4 Screws that goes around the fuel neck has to be changed out as well .
  5. Dec 17, 2023 at 11:49 AM
    ToyCam
    ToyCam New Member
    Paula
    2001 Black Tundra
    Love this idea. Im curious on what you did on the inner housing. Could you possibly send pics? Would you be into custom making one?
  6. Dec 17, 2023 at 12:29 PM
    I'd love to see pictures from inside the door! Just to see the framework, how it hinges out.
    ToyCam likes this.
