Replacing AC Clutch
Discussion in '1st Gen Tundras (2000-2006)' started by SteveT, Dec 9, 2022.
  1. Dec 9, 2022 at 7:40 AM
    SteveT
    SteveT [OP] New Member
    LugNutz
    2002 Tundra SR5 Access Cab
    None yet. Just good ole maintenance
    Is the process of swapping the AC clutch while compressor is installed very tricky at all? It looks very straight-forward to me, but was curious from anyone who has done it.
    Background - I have an intermittent slight pulley squeal when warming up the truck in below freezing temperatures which lasts about 5 mins. Just a PIA. Did it last winter and is back this winter. Since last year, I've done the full timing/WP job with all idlers/tensioner, replaced the fan clutch as it was bad, serpentine belt, drive belt pulley and tensioner unit. I started the truck with the serpentine removed and its quiet, so it must be either the alternator,PS, or AC pulleys. I have a stethoscope but really not helpful as the whole engine bay makes that thing loud. After spinning all 3 of those, the only one with much tension is the alternator I guess since its a wound motor. My ears are telling me it sounds closer to the AC side but its tough to tell. For under $100, I can give the AC clutch a shot. Thoughts?
    I should add that the AC system works great and there is no change of squeal when I put AC on or off. Looking to avoid system maint. since the AC works great.
    Thanks Guys! Steve
  2. Dec 9, 2022 at 7:43 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  3. Dec 9, 2022 at 7:46 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Even when these trucks were new, the belts would squeal. At the time, many would replace the original serpentine belt with a Goodyear Gatorback.
    My 04 would have a bit of noise when cold for just a little bit, then it would go away.
    If you go monkeying with hard parts like that, make certain that part is the issue.
    Jack McCarthy likes this.
  4. Dec 9, 2022 at 7:56 AM
    Beat me to it. @SteveT definitely read that TSB if you haven't already. Others reporting same symptoms have found that was the cause of the squeal, and during cold temps mainly.
    Here's the VIN start/stop ranges impacted:
  5. Dec 9, 2022 at 8:46 AM
    SteveT
    LugNutz
    Point well taken dt325ic. I'll give the Continental/Goodyear belt a shot if I can find it. My new one is Gates I believe.
  6. Dec 9, 2022 at 8:54 AM
    I love my Gates HD belt (green). Always take their stuff over Conti and GY.
  7. Dec 9, 2022 at 9:16 AM
    SteveT
    LugNutz
    Man I thought I was a decent Googler but I just can't find the part number of the "Elite" version of this belt for the 4.7. Only find the straight rib version and not shown on Continental part picker interface.
  8. Dec 9, 2022 at 9:48 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I think the old Gatorback/Elite style may have been discontinued.
    I always had good luck with the durability of OE belts, even with a slight noise when cold. The standard Gates belts are fine, but they don't last as long.
    The last belt that I had was either a Mitsuboshi or Bando -- I don't recall which -- but it was silent.
  9. Dec 9, 2022 at 10:57 AM
  10. Dec 9, 2022 at 11:17 AM
    SteveT
    LugNutz
    Thanks guys - I'll give the Gates HD a try. That TSB is interesting, I wish I knew about the updated tensioner when I had everything apart for the timing belt job. I used an ACDelco tensioner since the one I had ordered originally came with the wrong size pulley. I'm not pulling that stuff apart again for small squeal. Thanks!!
  11. Dec 16, 2022 at 8:09 AM
    SteveT
    LugNutz
    Update: With the Cont. Elite/Gator belt unavailable, I went with the Gates HD (green), and sorry to say the small squeal persists. Really not that big a deal, just annoying. Has anyone actually followed the TSB with the upgraded components and solved the squeal? I'm willing to go as far as the upgraded AC mount bracket, but not going to ever bother with the upgraded tensioner since I just installed a new one (ACDelco Gold 38173) during my timing belt job.
    TSB reposted here.
    shifty` likes this.
